Author Topic: Print Server Name Change?  (Read 16256 times)
SDETERS
Re: Print Server Name Change?
« Reply #15 on: February 09, 2010, 05:57:17 PM »
I get an error I checked this a couple of times error: Automation Error. Invalid input
This is how I have the code at the current time.  I am missing something  Once again thanks for the help
(vla-put-configname
  (vla-get-layout
    (vla-get-PaperSpace
      (vla-get-ActiveDocument
(vlax-get-object "AutoCAD.Application")
  "ME Assembly.pc3"
;; or
(vla-put-configname
  (vla-get-layout
    (vla-get-PaperSpace
  "None"
« Reply #16 on: February 09, 2010, 06:06:18 PM »
Shane,
Are you running this after importing the PageSetups from your template ?
Can you post(attach to post) the drawing after you've imported the Page Setups ?
Which code are you importing the PageSetups with ?
and what is the qualified filename for your template with the correct PageSetups?
« Reply #17 on: February 09, 2010, 08:58:20 PM »
<snip>
*humm?*
I'm interested in the answer to Kerry's questions too.
(vla-put-configname
      ;<snip>
  "ME Assembly.pc3"
;; or
(vla-put-configname
       ;<snip>
  "None"
Oh no problem at all; im just sorry I cant help more.
If youre running the code exactly as you show it, then we need to make at least one change.
Could you in addition to Kerry's questions could you run this snip of code for me please and let me know if you get the Automation Error again.
(vla-put-configname
  (vla-get-layout
    (vla-get-PaperSpace
  "ME Assembly.pc3"
Kerry, do you think the space in the driver name would cause that error?
« Reply #18 on: February 09, 2010, 09:03:47 PM »
Hi John,
Thats one of the things I wanted to check when I got Shane's files .. I don't recall ever using a space in the name myself.
.. but AutoCAD does use spaces, SO probably not.
« Reply #19 on: February 09, 2010, 09:16:12 PM »
w00t! I'm bookmarking this thread baby! The first time my mind was great. ...*blink* *gulp* dang, i hope it aint just statistics?!
SDETERS
« Reply #20 on: February 10, 2010, 08:51:30 AM »
Answers to Kerry questions.
Shane,
I am running this before.  SHould I be running it after?
I am attaching both files my template and a sample drawing.
The one that se7en suggested.  Maybe I need some step by step instructions.  Dang I am a noob when it come to this lisp stuff sorry
the name for the template file is "HG ME Template.dwt"
The example file that I am messing with is named EDST4_PART001.dwg
These will be both attached.  Um would it be better and or make life easier if there was no spaces in the file name?  I hoped I answered all of the questions.  Off to try se7en code
Once again thanks for the help.  I also attached a jpeg of the warning box I do not want showing up.  Our print named changed from hgrps1 to hgrps2
« Last Edit: February 10, 2010, 09:03:40 AM by SDETERS »
« Reply #21 on: February 10, 2010, 08:58:24 AM »
after.  Let me assemble one piece of code for you to run before i start downloading your files.
« Reply #22 on: February 10, 2010, 09:07:49 AM »
I gotta run, I got a fire here i have to put out. Run this and see what you get.
(defun c:psetup-test ( / )
   (setq *acad* (vlax-get-acad-object))
   (setq *active-document* (vla-get-activedocument *acad*))
       (defun copy_page-setup (DwgName / psetups $acadver$ $typelib$ $classname$ $dbxDoc$)
           (setq $AcadVer$  (atoi (getvar "acadver"))
                 $TypeLib$   (findfile "AxDb.dll")
                 $ClassName$ (strcat "ObjectDBX.AxDbDocument" "." (itoa $AcadVer$))
                 $dbxdoc$   (vla-GetInterfaceObject (vlax-get-acad-object) $ClassName$))
           (setq psetups (vla-get-plotconfigurations *active-document*))
           (vla-open $dbxdoc$ DwgName)
           (vlax-for x
                     (setq dbxdoc-collection (vla-get-plotconfigurations $dbxdoc$))
                     (setq name (vla-get-name x))
                     (vla-copyobjects
                       $dbxdoc$
                       (vlax-safearray-fill
                         (vlax-make-safearray vlax-vbobject '(0 . 0))
                         (list (vla-item dbxdoc-collection name)))
                       psetups ))
           (vlax-release-object $dbxdoc$)
   ;; delete existing pagesetups
   (vlax-map-collection (vla-get-plotconfigurations *active-document*) 'vla-delete)
   ;; import the new ones
   (copy_page-setup "C:\\HG ME Template.dwt")
   (vla-put-configname
     (vla-get-layout
       (vla-get-PaperSpace
     "ME Assembly.pc3"
  (princ "\nType \"Psetup-test\" for the test.")
« Reply #23 on: February 10, 2010, 09:08:50 AM »
oh and note the path to your template, fix if you need to.
SDETERS
« Reply #24 on: February 10, 2010, 09:28:51 AM »
Ok ran the code
It ran just fine.
I still get that JPEG error box I have attached in the previous post when I go to plot.
« Reply #25 on: February 10, 2010, 09:58:25 AM »
Ok, i think i'm almost got this figured out. If im correct then all that is left is just a little bit of code.
Run this line please.
(vlax-map-collection (vla-get-layouts *active-document*) '(lambda ( x ) (vla-put-configname x "None")))
Try to plot.
SDETERS
« Reply #26 on: February 10, 2010, 10:56:02 AM »
I ran the psetup-test then I ran your small line of code in your previous post.
This now sets my printer to none.  Great This eliminates my jpeg warning
What would be even better would be to set my Printer to the appropriate network printer.
Could this be done by changing none to the printer name?
« Reply #27 on: February 10, 2010, 11:00:17 AM »
lol we are on the same page my friend.
« Reply #28 on: February 10, 2010, 11:18:25 AM »
Here ya go.
Replace/fix the two lines as you need to.
Call the command from the command line like: psetup-reset
or
Call the command from a button or another lisp like: (c:psetup-reset)
(defun c:psetup-reset ( / )
           (vlax-for x
                     (vla-copyobjects
                       $dbxdoc$
                       psetups ))
   ;; apply the default printer driver to all the layouts
     '(lambda ( x ) (vla-put-configname x "ME Assembly.pc3")))
  ;; release the obj's
  (mapcar 'vlax-release-object (list *acad* *active-document*))
SDETERS
« Reply #29 on: February 10, 2010, 11:31:33 AM »
Great I think this will work.  Please stay tuned I may have a question about *.pc3 files.  Thanks again  This is great
