Hi all...
I have a question regarding MESHSMOOTH command...
If I have selection set of boxes 3DSOLID primitives, when I enter or run through lisp (command "_.MESHSMOOTH" ss "") everything is fine - all primitives are converted to appropriate MESHES according to settings of MESH sysvars...
Now that's fine and good, but the problem arises in just slightly different situation :
If boxes aren't primitives - already had some kind of modeling operation performed UNION, SUBTRACT, INTERSECT, or similar when typed from command line (command "_.MESHSMOOTH" ss ""), CAD doesn't do anything... What's weird, when typed MESHSMOOTH directly from command line and 3DSOLIDS are selected, CAD do what should... So can anyone unlock this odd behaviour if 3DSOLIDS are complex and (command "_.MESHSMOOTH" ss "") function is used through LISP...
