Author Topic: Discerning eyes needed..!  (Read 3509 times)
Water Bear
« on: March 20, 2005, 05:46:04 PM »
Can anyone see why the following code doesn't work...
if I keep the value = "1"; in the DCL the routine crashes miserably...if I leave them out the routine runs fine except that the default buttons are not highlighted.. am I using the wrong expression?
from the DCL file:
centrifugal : dialog { //dialog name
label = "Centrifugal Fan Selection" ;
: row {
   : boxed_radio_column {
    label="Fan Desigantion";
    : edit_box {key = "T"; label = "Tag:"; edit_width = 10;}
    : edit_box {key = "C"; label = "CFM:"; edit_width = 10;}
: boxed_column {
 label = "Fan Selection" ;
: popup_list {
label = "Select the Make:";
key = "K";
value = "0" ;
edit_width = 18;
: popup_list {
label = "Select the Model:";
key = "D";
value = "0" ;
edit_width = 18;
    spacer_1;
    : boxed_radio_row {
        label = "Discharge";
        : radio_button {label = "TH";key = "_TH";value = "1" ;}
        : radio_button {label = "TAD";key = "_TAD";}
        : radio_button {label = "DB";key = "_DB";}
        : radio_button {label = "BAD";key = "_BAD";}
        : radio_button {label = "BH";key = "_BH";}
        : radio_button {label = "BAU";key = "_BAU";}
        : radio_button {label = "UB";key = "_UB";}
        : radio_button {label = "TAU";key = "_TAU";}
} //end row
spacer_1;
  : row {//start row
  spacer_1;
        label="View";
        : radio_button {label = "Plan";key = "P";value = "1" ;}
        : radio_button {label = "Elevation";key = "E";}
    : boxed_radio_row {
       label = "Motor Location";
        : radio_button {label = "C";key = "_C";value = "1" ;}
        : radio_button {label = "W";key = "_W";}
        : radio_button {label = "X";key = "_X";}
        : radio_button {label = "Y";key = "_Y";}
        : radio_button {label = "Z";key = "_Z";}
spacer_1;
    : boxed_radio_column {//start row
        label = "Rotation";
        : radio_button {label = "Clockwise";key = "_CW";value = "1" ;}
        : radio_button {label = "CounterClockwise";key = "_CCW";}
       }//end row
spacer_1;
ok_cancel ; //predefined OK/Cancel button
spacer_1;
logo;
mushroom : dialog { //dialog name
label = "Mushroom Fan Selection" ;
  : row {
   : edit_box {label = "Tag:";key = "T";edit_width = 10;}
   : edit_box {label = "CFM:";key = "C";edit_width = 10;}
   label="View";
        : radio_button {label = "Plan";key = "P";value="1";}
 : boxed_column{
     : popup_list {
       key = "K";
       value = "0" ;
       edit_width = 18;
     : popup_list {
       key = "D";
       value = "0" ;
       edit_width = 18;
spacer_1;
spacer_1;
logo;
from the LSP file:
  (start_list "K")
  (mapcar 'add_list makes)
  (end_list)
  (start_list "D")
  (mapcar 'add_list models)
  (end_list)
  ;;default rotation angle
  (set_tile "C" cfm)
  (set_tile "T" tag)
  ;;setup the Cancel button
  (action_tile
    "cancel"
    "(done_dialog) (setq userclick nil)"
  (action_tile "P" "(setq view \"P\")")
  (action_tile "E" "(setq view \"E\")")
  (action_tile "_W" "(setq motor \"W\")")
  (action_tile "_X" "(setq motor \"X\")")
  (action_tile "_C" "(setq motor \"C\")")
  (action_tile "_Y" "(setq motor \"Y\")")
  (action_tile "_Z" "(setq motor \"Z\")")
  (action_tile "_CW" "(setq naut \"CW\")")
  (action_tile "_CCW" "(setq naut \"CCW\")")
  (action_tile "_TH" "(setq disch \"TH\")")
  (action_tile "_TAD" "(setq disch \"TAD\")")
  (action_tile "_DB" "(setq disch \"DB\")")
  (action_tile "_BAD" "(setq disch \"BAD\")")
  (action_tile "_TAU" "(setq disch \"TAU\")")
  (action_tile "_UB" "(setq disch \"UB\")")
  (action_tile "_BAU" "(setq disch \"BAU\")")
  (action_tile "_BH" "(setq disch \"BH\")")
  ;;setup the OK button
  (action_tile
    "accept"
    (strcat
      "(progn (setq make  (atof (get_tile \"K\"))
          model (atof (get_tile \"D\"))
                   cfm (atof (get_tile \"C\"))
                   tag (strcase(get_tile \"T\"))
      "(done_dialog) (setq userclick T))"
  ;;display the dialog
  (start_dialog)
  ;;unload the dialog
  (unload_dialog dcl_id)
  ;;now open file and get fan data
  (cond (userclick...yada yada
whdjr
« Reply #1 on: March 21, 2005, 11:22:33 AM »
Which "default button" are you referring too?
You used a bunch of them.
« Reply #2 on: March 21, 2005, 11:35:58 AM »
You got me confused with the line
logo;
I had to comment it out to display the DCL box.
Everything looked ok after that?
What does that line do?
« Reply #3 on: March 21, 2005, 11:44:33 AM »
Just ran a test lsp with the DCL, logo comment out & it ran fine for me in ACAD2000.
Water Bear
« Reply #4 on: March 21, 2005, 01:44:39 PM »
Thanks for the response guys. Let me see if I can explain it a bit better. The dcl file loads fine in the preview window whether the radio buttons are defaulted or not. The problem is when I run it from the lsp file. If I set the radio buttons to a default via (value = "1"; ) the lsp crashes. It will work with no defaults set try it... remember to set  all the radios ! P.S. I haven't developed the "plan view" yet so try the elevation view.
;; save as swamp.dat
;;;Fan specifications
**make
*model
**MANUFACTURER1
*MODEL1
23.0,12.0,22.25,2.0,15.5,9.625,13.0,15.125,13.0,16.875,28.375,13.25,21.375,9.75,1.5,16.0,21.375,16.0
*MODEL2
41.5,19.75,45.125,2.5,25.0,19.0,25.875,31.5,26.0,33.625,57.75,26.25,40.625,17.75,1.5,31.125,36.0,31.125
**MANUFACTURER2
*MODEL2
*MODEL1
;;end of swamp.dat
//;; save as swamp.dcl
// logo dialog
logo
   :text_part {
      label = "Gators @ The Swamp ©2005";
      alignment=centered;
      is_bold=true;
: row {
: boxed_column {
: popup_list {
key = "K";
value = "0" ;
edit_width = 18;
: popup_list {
key = "D";
value = "0" ;
edit_width = 18;
    spacer_1;
    : boxed_radio_row {
        : radio_button {label = "TH";key = "_TH";}
} //end row
spacer_1;
  : row {//start row
  spacer_1;
        label="View";
        : radio_button {label = "Plan";key = "P";}
    : boxed_radio_row {
        : radio_button {label = "C";key = "_C";}
spacer_1;
        label = "Rotation";
        : radio_button {label = "Clockwise";key = "_CW";}
       }//end row
spacer_1;
spacer_1;
logo;
//; end of swamp.dcl
;; save as swamp.lsp
(defun centrifugal (/ dcl_id makes models make model tag cfm name_file fp line char lst naut rotdis
   disch view A B C D E F H J K L M N O P Q R S TT dlist ans pt1 pt2 pt3 pt4 pt5
   pt6 pt7 pt8 pt9 pt10 pt11 pt12 pt13 pt14 pt15 pt16 pt17 cp disang r1 r2 r3 tsp1
   tsp2 applic grp
;(init)
  (load_utilities)
  ;;load the dialog
  (setq dcl_id (load_dialog "swamp.dcl")
makes  '("Manufacturer1" "Manufacturer2")
models '("Model1" "Model2")
tag    "EF-"
cfm    "VERIFY"
  (if (not (new_dialog "centrifugal" dcl_id))
    (exit)
  ;;setup the list box
  (start_list "K")
  (end_list)
  (start_list "D")
  (end_list)
  (set_tile "C" cfm)
  (set_tile "T" tag)
  (action_tile
    "cancel"
  (action_tile
    "accept"
    (strcat
                   cfm (strcase(get_tile \"C\"))
  (start_dialog)
  ;;unload the dialog
    (userclick
     (setq make (strcase
  (strcat "**" (nth (fix make) makes))
  model (strcase
  (strcat "*" (nth (fix model) models))
     (setq name_file (findfile "swamp.dat"))
       (name_file
(setq fp (open name_file "r"))
(while (setq line (read-line fp))
 (setq char (substr line 1 2))
   ((= char ";"))
   ((= char "**")
      ((= make line)
(while (and (not lst)
   (/= "**" (substr (setq line (read-line fp)) 1 2))
 (setq char (substr line 1 1))
 (cond ((= char ";"))
((= char "*")
(and (= model line) (setq lst (read-line fp)))
(close fp)
  (cond (lst
;; make dlist all reals
(setq dlist (car
      (mapcar ; repeat the function foreach item in the list
(function (lambda (n) (str2nums n ",")))
(list ; added this to make it a list
  lst ; this returns the data as a string
(mapcar 'set
'(A B C D E F H J K L M N O P Q R S TT)
dlist
;;got data now draw the fan
(if (null (tblsearch "layer" "M-Equipment Detail"))
  (equipment_layers)
(setq rotdis (strcat naut disch))
(cond ((= view "E")
(cond ((or (= rotdis "CWTH") (= rotdis "CCWBH"))
      (setq disang 0)
     ((or (= rotdis "CWTAU") (= rotdis "CCWBAU"))
      (setq disang (dtr 45.0))
     ((or (= rotdis "CWUB") (= rotdis "CCWUB"))
      (setq disang (dtr 90.0))
     ((or (= rotdis "CWBAU") (= rotdis "CCWTAU"))
      (setq disang (dtr 135.0))
     ((or (= rotdis "CCWTH") (= rotdis "CWBH"))
      (setq disang (dtr 180.0))
     ((or (= rotdis "CCWTAD") (= rotdis "CWBAD"))
      (setq disang (dtr 225.0))
     ((or (= rotdis "CCWDB") (= rotdis "CWDB"))
      (setq disang (dtr 270.0))
     ((or (= rotdis "CWTAD") (= rotdis "CCWBAD"))
      (setq disang (dtr 315.0))
 ((and (not Q) (<= H 15.0)) (setq Q 2.0))
 ((and (not Q) (> H 15.0)) (setq Q 4.0))
(setvar "osmode" 2)
(setq pt1 (upoint 1 "" "Select midpoint of curb" nil nil))
(setvar "osmode" 0)
(setq cp   (polar pt1 (dtr 90.0) J)
     R1   (/ (+ (- P Q) (* J 0.6)) 2.0)
     R2   (/ (+ (- O P) (* J 0.6)) 2.0)
     R3   (/ (+ (- O P) N) 2.0)
     pt2  (polar pt1 0 (/ L 2.0))
     pt3  (polar pt1 0 (/ TT 2.0))
     pt4  (polar pt3 (dtr 180.0) (distance pt3 pt2))
     pt11 (polar pt2 (dtr 180.0) L)
     pt10 (polar pt1 (dtr 180.0) (/ TT 2.0))
     pt9  (polar pt11 0 (distance pt4 pt2))
     pt5  (polar pt4
 (dtr 90.0)
 (- C (/ (distance pt9 pt4) 3.0))
     pt6  (polar pt5
 (dtr 135.0)
 (* (/ (distance pt9 pt4) 3.0) (cosecant (dtr 45.0)))
     pt7  (polar pt6 (dtr 180.0) (/ (distance pt9 pt4) 3.0))
     pt8  (polar pt7
 (dtr 225.0)
(command "layer" "s" "M-Equipment Detail" "")
(command "linetype" "s" "hidden" "")
(command "circle" cp "d" H)
(setq grp (ssget "L"))
(setq tsp1 (polar cp (dtr 90.0) (/ H 2))
     tsp2 (polar tsp1 (dtr 270.0) H)
(command "pline"
tsp1
"a"
"r"
(/ H 4.0)
cp
tsp2
(harvest)
(command "linetype" "s" "bylayer" "")
;; fan below
(if (= "CCW" (substr rotdis 1 3))
 (setq factor -1.0)
 (setq factor 1.0)
(setq pt15 (polar cp (+ disang (* factor (dtr 90.0))) N)
     pt14 (polar pt15 disang P)
     pt13 (polar pt14 (+ disang (* factor (dtr 270.0))) K)
     pt12 (polar pt13 (+ disang (* factor (dtr 180.0))) Q)
     pt16 (polar cp (+ disang (* factor (dtr 180.0))) (- O P))
     pt17 (polar cp (+ disang (* factor (dtr 270.0))) (* J 0.6))
(command "layer" "s" "M-Equipment" "")
 (command "pline" pt14 pt13 pt12 "a" "r" R1 pt17 "r" R2 pt16 "r" R3 pt15 "l" pt14
 (command "pline" pt13 pt14 pt15 "a" "r" R3 pt16 "r" R2 pt17 "r" R1 pt12 "l" pt13
(harvest)
(command "circle" cp "d" 1.5)
(harvest)
(command "pline" pt2 pt4 pt5 pt6 pt7 pt8 pt9 pt11 "c")
(harvest)
      ) ; end elevation view
      (T
(setq applic (vlax-get-acad-object))
(vla-eval
 applic
 (strcat
   "MsgBox \"Plan view not yet available...\"" ", " "vbInformation" ", "
   "\"Swamp\""
(setq tp2
(upoint 1 "" "Select BOTTOM LEFT for text location" nil nil)
(command "layer" "S" "M-Equipment Text" "")
(command "-insert"
 "Equip Tag"
 tp2
 "25"
 "0"
 tag
 (strcat (rtos H 5 2) "\"%%C Inlet")
 (strcat (rtos K 5 2)
 "\" x "
 (rtos F 5 2)
 "\" Disch"
 cfm
 "-CFM)"
 (strcat "Model: " (substr model 2) " " rotdis)
 (strcat "Motor Position: \"" motor "\"")
(harvest)
(if grp
  ;; we can get rid of this when plan view is developed
  (command "-group" "c" "*" "" grp "")
(T
(vla-eval
  applic
  (strcat
    "MsgBox \"Fan Data was not found Make and/or Model not listed...\"" ", "
    "vbInformation" ", " "\"Swamp\""
;(reset)
(defun load_utilities ()
  (defun equipment_layers ()
    (command "layer" "m" "M-Equipment" "c" "1" "" "lw" ".80" "" ""
    (command "layer" "m" "M-Equipment Text" "c" "240" "" "lw" ".00" "" ""
    (command "layer" "m" "M-Equipment Detail" "c" "30" "" "lw" "0" "" ""
  (defun upoint (bit kwd msg def bpt / inp)
    (if def
      (setq pts (strcat (rtos (car def))
(rtos (cadr def))
(if (and (caddr def) (= 0 (getvar "FLATLAND")))
 (strcat "," (rtos (caddr def)))
   msg (strcat " \n" msg " <" pts ">: ")
   bit (- bit (boole 1 bit 1))
      (if (= " " (substr msg (strlen msg) 1))
(setq msg (strcat "\n" msg (substr msg 1 (1- (strlen msg))) ": "))
(setq msg (strcat "\n" msg ": "))
    (initget bit kwd)
    (setq inp
  (if bpt
    (getpoint msg bpt)
    (getpoint msg)
    (if inp
      inp
      def
  (defun harvest () ; these are global set local @ main routine
    (setq grp (ssadd (entlast) grp))
  (defun str2nums (aStr delim / strList pos)
    (while (setq pos (vl-string-search delim aStr 0))
      (setq strList (cons (substr aStr 1 POS) strList)
   aStr    (substr aStr (+ pos 2))
    (reverse (cons aStr strList))
    (mapcar 'atof (reverse (cons aStr strList)))
;; end of swamp.lsp
Water Bear
whoops.. you need this block
« Reply #5 on: March 21, 2005, 01:58:17 PM »
http://www.theswamp.org/lilly_pond/waterbear/Equip%20Tag.dwg?nossi=1
if url doesn't work, you'll find it in the pond as waterbear/equip tag.dwg
Water Bear
a little help here.....pleeze
« Reply #6 on: March 27, 2005, 09:09:16 PM »
It seems that I can't find the cause...as i'm new to DCL ...what the heck am I doing wrong!!! :(
« Reply #7 on: March 27, 2005, 09:26:53 PM »
I use this to pre set the radio buttons, but I did try value="1";
and it worked fine for me, I did find errors in another part of the
code.
 (set_tile "P" "1")
  (set_tile "_C" "1")
  (set_tile "_TH" "1")
  (set_tile "_CW" "1")
« Reply #8 on: March 27, 2005, 09:57:15 PM »
Two things here in this code,
Note that in the data file the string "**MANUFACTURER1 " has a trailing space and therefore
fails the test (= make line)
I did not do anymore testing but the routine does not read the data list.
Needs more code revision.
            ((= char ";;")) ;  <------<<  change this *****************
            ((= char "**")
               ((= make (vl-string-trim " " line)) ;   <-------<<<  change this  **********
                        ((= char "*")
                         (and (= make (vl-string-trim " " line)) ; <---<<< change this  **********
        ) ; end while
Water Bear
« Reply #9 on: March 28, 2005, 12:09:40 PM »
Thanks for the help CAB...I've got it to work ONLY if radio buttons are actually picked. If PDB comes up and I select OK (use all defaults as shown) I get an error "stringp nil"  :cry:  apparently it is setting the radio buttons to "on" but it does not set the variables.
