CAD Forums > CAD General
CAD File is 63MB with images
HasanCAD:
I copies images in cad file, CAD file without images is 0.5 MB and images total 2.0MB
But the CAD file now is 63.0MB
Why is this?
How to reduce the file size?
rkmcswain:
You pasted these in? And now they are OLE objects?
If you make a copy of this DWG, and start deleting things, when does the file size drop?
IOW - Trial and error
HasanCAD:
--- Quote from: rkmcswain on January 17, 2024, 08:55:23 AM ---You pasted these in? And now they are OLE objects?
--- End quote ---
Yes, I Pasted these in, They Are OLE object.
--- Quote from: rkmcswain on January 17, 2024, 08:55:23 AM ---If you make a copy of this DWG, and start deleting things, when does the file size drop?
--- End quote ---
I deleted all objects, but the file is 30MB.
The file is empty.
https://1drv.ms/u/s!ApyYNfqm2se6nUUaWSCprbmm3zbG?e=7sPLTi
57gmc:
It contains a non-purgable block that is used by render lights. It is also why you can't delete some layers.
HasanCAD:
Thanks 57gmc
Navigation
[0] Message Index
[#] Next page
Go to full version
