CAD Forums > CAD General
Find Text in a Closed Drawing
whdjr:
CAB,
I looked over your drawing and it keeps crashing when it comes across your block "20GOBLT01". I can't figure out why except that it says it has attributes, but when the program tries to get them its empty and therefore crashes. I think I can catch the error with
vl-catch-all-apply and then I'll post the revision.
That's a strange one. Anyone else got any ideas why a block would show a True flag for attributes, but then wouldn't have any? :? :? :?
whdjr:
CAB,
Here is the revised code that works on your file here in my office. I made a few modifications to show how many pieces of text, mtext, or attdefs you had in a drawing or wether that dwg was already open.
Give this one a spin and let me know. :wink:
--- Code: ---(vl-load-com)
(defun *error* (msg)
(princ "\nError: ")
(princ msg)
(if (and dbxdoc (not (vlax-object-released-p dbxdoc)))
(vlax-release-object dbxdoc)
(gc)
(defun DLLRegister (dll)
(startapp "regsvr32.exe" (strcat "/s \"" dll "\""))
(defun ProgID->ClassID (ProgID)
(vl-registry-read
(strcat "HKEY_CLASSES_ROOT\\" progid "\\CLSID")
(defun DBX-Register (/)
(setq classname "ObjectDBX.AxDbDocument")
((ProgID->ClassID classname))
((and
(setq server (findfile "AxDb15.dll"))
(DLLRegister server)
((not (setq server (findfile "AxDb15.dll")))
(alert
"Error: Cannot locate ObjectDBX Type Library (AxDb15.dll)..."
(T
(DLLRegister "ObjectDBX.AxDbDocument")
(or
(ProgID->ClassID "ObjectDBX.AxDbDocument")
(alert
"Error: Failed to register ObjectDBX ActiveX services..."
(defun findphrase (phrase document / txtcount mtxtcount attcount oName)
(setq txtcount 0
mtxtcount 0
attcount 0
(vlax-for item (vla-get-modelspace document)
(setq oName (vla-get-ObjectName item))
(cond ((eq oName "AcDbText")
(if (vl-string-search phrase (vla-get-textstring item))
(setq txtcount (1+ txtcount))
((eq oName "AcDbMText")
(setq mtxtcount (1+ mtxtcount))
((and (eq oName "AcDbBlockReference")
(eq (vla-get-hasattributes item) :vlax-true)
(foreach for-item (get_atts item)
(if (vl-string-search phrase (vla-get-textstring for-item))
(setq attcount (1+ attcount))
(list txtcount mtxtcount attcount)
(defun get_atts (obj / val)
(if (vl-catch-all-error-p
(vl-catch-all-apply
'(lambda ()
(setq val (vlax-safearray->list
(vlax-variant-value
(vla-getattributes obj)
nil
val
(defun c:tfar (/ file files str dbxdoc of lst wil classname)
(setq file "")
(while (setq file (getfiled "Select a file to replace text in" file "dwg" 128))
(setq files (cons file files))
(cond ((not files) (princ "No files were selected."))
((not (setq str (getstring T "Enter search phrase? ")))
(princ "\nSearch phrase is missing. ")
((not (DBX-Register)) (princ "Unable to load ObjectDBX."))
((not (setq dbxdoc (vla-GetInterfaceObject
(vlax-get-acad-object)
classname
(T
(foreach f (reverse files)
(setq of (vl-catch-all-apply
'(lambda ()
(vlax-invoke-method dbxdoc 'open f)
lst (if (vl-catch-all-error-p of)
(list f "File was read only. ")
(list f (findphrase str dbxdoc))
wil (cons lst wil)
(gc)
(textscr)
(mapcar '(lambda (x)
(princ
(strcat "\n"
(car x)
(cond ((eq (type (cadr x)) 'LIST)
(apply 'strcat
(mapcar '(lambda (y z)
(strcat "\n" (itoa y) z)
(cadr x)
'(" text entities matched your phrase."
" mtext entities matched your phrase."
" attribute reference entities matched your phrase.\n"
(T (strcat "\n" (cadr x))
wil
--- End code ---
CAB:
--- Quote from: whdjr ---CAB,
--- End quote ---
Will,
The block is one created by Arch-T. The attribute has a tag 'Go-Bolt' which
displays on the screen and was used to make a slide so the slide has a
visible label in the original drawing but will not be displayed when inserted
as the attribute is empty.
That is my understanding of it anyway.
CAB:
Command: tfar
Enter search phrase? trusses @16" oc
That seemed to work, although case sensitive.
--- Quote ---Command: tfar
Enter search phrase? trusses @ 16" oc
C:\Program Files\ACAD2000\=Active Projects\Steve Carter\4225 Morrison\4225
Morrison Master 1.DWG
0 text entities matched your phrase.
0 mtext entities matched your phrase.
0 attribute reference entities matched your phrase.
Command:
Command:
Command:
Command: _open
Command: tfar
Enter search phrase? PRE MFG TRUSSES @ 16" OC
3 text entities matched your phrase.
Command:
Command: PRE PREVIEW
Press ESC or ENTER to exit, or right-click to display shortcut menu.
Command: tfar
Enter search phrase? TRUSSES @ 16" OC
Command:
--- End quote ---
Message when file was open:
File was read only.
--- End quote ---
whdjr:
Glad that worked for you.
Navigation
[0] Message Index
[*] Previous page
Go to full version
