Author Topic: reconstruct polylines lines arcs cut  (Read 1482 times)
sergeluc
« on: February 21, 2012, 08:48:37 AM »
hello,
excuse ,my english is not perfect .
I try to rebuild same kinds of entities cut "lines *polylines or arcs" from a windows selection .The form entities (coplanar) are deleted and replaced by a single.
I enclose for example this routine ,it works by Two Entities selection.
(this lisp wasn't made ​​by me).
thank for your help
(defun REC-exct ( / ENTS1 ENTG1 EL ENTS2 ENTG2)
  (setq CL (getvar "CLAYER"))
  (setvar "CMDECHO" 0)
  (setq ENTS1 (car (entsel "\nPremiere entite")))
  (setq ENTG1 (entget ENTS1))
  (setq EL (cdr (assoc 8 ENTG1)))
  (setq ENTS2 (car (entsel "\nDeuxieme entite")))
  (setq ENTG2 (entget ENTS2))
  ((and (= (cdr (assoc 0 ENTG1)) "LINE")
           (= (cdr (assoc 0 ENTG2)) "LINE")
      ) ;_ Fin de and
      (setq P1 (cdr (assoc 10 ENTG1))
            P2 (cdr (assoc 11 ENTG1))
            P3 (cdr (assoc 10 ENTG2))
            P4 (cdr (assoc 11 ENTG2))
      ) ;_ Fin de setq
      (command "_LAYER" "_S" EL "")
      (entdel ENTS1)
      (entdel ENTS2)
      (if (> (distance P1 P3) (distance P1 P4))
        (setq P5 P1
              P6 P3
        ) ;_ Fin de setq
        (setq P5 P1
              P6 P4
        ) ;_ Fin de setq
      ) ;_ Fin de if
      (if (> (distance P2 P3) (distance P2 P4))
        (setq P7 P2
              P8 P3
        ) ;_ Fin de setq
        (setq P7 P2
              P8 P4
        ) ;_ Fin de setq
      ) ;_ Fin de if
      (if (> (distance P5 P6) (distance P7 P8))
        (command "_LINE" P5 P6 "")
        (command "_LINE" P7 P8 "")
      ) ;_ Fin de if
      (command "_LAYER" "_S" CL "")
      (setvar "CMDECHO" 1)
    ) ;_ Fin de progn
  ) ;_ Fin de 1er cond
  ((and
           (= (cdr (assoc 0 ENTG1)) "POLYLINE")
           (= (cdr (assoc 0 ENTG2)) "POLYLINE")
      ) ;_ Fin de and
      (setq PW (cdr (assoc 40 ENTG1)))
      (command "_EXPLODE" ENTS1)
      (setq ENTS1 (entlast))
      (command "_EXPLODE" ENTS2)
      (setq ENTS2 (entlast))
      ) ;_ Fin de setq
      (entdel ENTS1)
      (entdel ENTS2)
        (setq P5 P1
              P6 P3
        ) ;_ Fin de setq
        (setq P5 P1
              P6 P4
        ) ;_ Fin de setq
      ) ;_ Fin de if
        (setq P7 P2
              P8 P3
        ) ;_ Fin de setq
        (setq P7 P2
              P8 P4
        ) ;_ Fin de setq
      ) ;_ Fin de if
        (command "_PLINE" P5 "_W" PW "" P6 "")
        (command "_PLINE" P7 "_W" PW "" P8 "")
      ) ;_ Fin de if
    ) ;_ Fin de progn
  ) ;_ Fin de 2eme cond
  ((and
           (= (cdr (assoc 0 ENTG1)) "LWPOLYLINE")
           (= (cdr (assoc 0 ENTG2)) "LWPOLYLINE")
      ) ;_ Fin de and
      ) ;_ Fin de setq
      (entdel ENTS1)
      (entdel ENTS2)
        (setq P5 P1
              P6 P3
        ) ;_ Fin de setq
        (setq P5 P1
              P6 P4
        ) ;_ Fin de setq
      ) ;_ Fin de if
        (setq P7 P2
              P8 P3
        ) ;_ Fin de setq
        (setq P7 P2
              P8 P4
        ) ;_ Fin de setq
      ) ;_ Fin de if
      ) ;_ Fin de if
    ) ;_ Fin de progn
  ) ;_ Fin de 3eme cond
  ((and (= (cdr (assoc 0 ENTG1)) "ARC")
           (= (cdr (assoc 0 ENTG2)) "ARC")
      ) ;_ Fin de and
      (setq
        CA (strcase (getstring "\nChanger arcs en cercle? Y or <N> "))
      ) ;_ Fin de setq
      (if (= CA "Y")
                RA (cdr (assoc 40 ENTG1))
          ) ;_ Fin de setq
          (entdel ENTS1)
          (entdel ENTS2)
          (command "_CIRCLE" P1 RA)
        ) ;_ Fin de progn
          (setq 150X (car (polar (cdr (assoc 10 ENTG1))
                                 (cdr (assoc 50 ENTG1))
                          ) ;_ Fin de polar
                     ) ;_ Fin de car
                150Y (cadr (polar (cdr (assoc 10 ENTG1))
                           ) ;_ Fin de polar
                     ) ;_ Fin de cadr
                151X (car (polar (cdr (assoc 10 ENTG1))
                                 (cdr (assoc 51 ENTG1))
                          ) ;_ Fin de polar
                     ) ;_ Fin de car
                151Y (cadr (polar (cdr (assoc 10 ENTG1))
                           ) ;_ Fin de polar
                     ) ;_ Fin de cadr
                250X (car (polar (cdr (assoc 10 ENTG2))
                                 (cdr (assoc 50 ENTG2))
                                 (cdr (assoc 40 ENTG2))
                          ) ;_ Fin de polar
                     ) ;_ Fin de car
                250Y (cadr (polar (cdr (assoc 10 ENTG2))
                           ) ;_ Fin de polar
                     ) ;_ Fin de cadr
                251X (car (polar (cdr (assoc 10 ENTG2))
                                 (cdr (assoc 51 ENTG2))
                          ) ;_ Fin de polar
                     ) ;_ Fin de car
                251Y (cadr (polar (cdr (assoc 10 ENTG2))
                           ) ;_ Fin de polar
                     ) ;_ Fin de cadr
                AP1  (list 150X 150Y)
                AP2  (list 151X 151Y)
                AP3  (list 251X 251Y)
          ) ;_ Fin de setq
          (entdel ENTS1)
          (entdel ENTS2)
          (command "_ARC" AP1 AP2 AP3)
        ) ;_ Fin de progn
      ) ;_ Fin de if
    ) ;_ Fin de progn
);cond generales
) ;_ Fin de defun
I enclose also another lisp, which only works for lines , but it's the type of selection what I want .
;serves to rebuild broken [u]lines[/u] by selection window
 ;      PROJ    Projection du point A sur la droite B C avec verification
 ;              selon D comme la fonction INTERS
(defun _proj (a b c d)
  (inters b
          c
          a
                (polar a (+ (* 0.5 pi) (angle  b c)) 1.0)
          d
(defun c:reb-lig ( / p q lot la i lb ea eb d p1 p2 p3 p4 d1 d2 ea10 ea11 eb10 eb11 temp)
(setq p nil q nil)
  (initget 1)
  (setq p (getpoint "\nPremier coin : "))
  (initget 1)
  (setq q (getcorner p "\nAutre coin : "))
(setvar "cmdecho" 0)
  (command "_erase" "_w" p q "")
  (if (setq lot (ssget "c" p q))
      (while (setq la (ssname lot 0))
        (ssdel la lot)
        (setq i 0)
        (repeat (sslength lot)
          (setq lb (ssname lot i))
          (setq ea (entget la))
          (setq eb (entget lb))
          (setq d
                 (apply '(lambda (e1 e2)
                           (if (= "LINE" (cdr (assoc 0 e1)) (cdr (assoc 0 e2)))
                               (setq p1 (cdr (assoc 10 e1))
                                     p2 (cdr (assoc 11 e1))
                                     p3 (cdr (assoc 10 e2))
                                     p4 (cdr (assoc 11 e2))
                                     d1 (distance p1 (_proj p1 p3 p4 nil))
                                     d2 (distance p2 (_proj p2 p3 p4 nil))
                               (if (> 0.001 (abs (- d1 d2)))
                                 d1
                                 nil
                        (list ea eb)
          (cond ((not d) nil)
                ((> 0.001 (abs d))
                 (if (= (cdr (assoc 8 ea)) (cdr (assoc 8 eb)))
                     (setq ea10 (cdr (assoc 10 ea))
                           ea11 (cdr (assoc 11 ea))
                           eb10 (cdr (assoc 10 eb))
                           eb11 (cdr (assoc 11 eb))
                     (if (> (distance ea10 eb10)
                            (distance ea10 eb11)
                       (setq temp eb10
                             eb10 eb11
                             eb11 temp
                     (if (< (distance ea10 eb10)
                            (distance ea11 eb10)
                       (setq temp ea10
                             ea10 ea11
                             ea11 temp
                     (entdel lb)
                     (entmod (append ea
                                     (list (cons 10 ea10)
                                           (cons 11 eb11)
                     T
                (T nil)
          (setq i (1+ i))
  (setvar "highlight" 1)
  (redraw)
« Last Edit: February 23, 2012, 04:28:03 AM by sergeluc »
