I have a 600 drawings I need to do a bunch of stuff too. I have a button that loads a simple lisp routine that I usually use but 600 drawings....each on at a time...I don't have time to do that. IS there any way I can load the lisp's in a SCRIPT files and then batch it using scriptpro?
here is what I did, I thought it would work but obviously it isnt.
;Sets Undo Control to Off
Undo control none
;Sets Viewres 10000
viewres
y
10000
fieldeval
31
LAYEREVAL
0
LAYERNOTIFY
0
visretain
1
;Enter new value for INSUNITS (0=unitless, 1=inches, 4=millimeter)
insunits
4
insunitsdefsource
4
insunitsdeftarget
4
(COMMAND "IMAGEFRAME" "0")
(load "C:/xxxx/lisp/XLAYER.LSP")
(XLAYER)
(load "C:/xxxx/lisp/clean.vlx")
(clean)
(load "C:/xxxx/lisp/PURGNEST.LSP")
(PURGNEST)
(load "C:/xxxx/lisp/xclean.lsp")
(xclean)
(COMMAND "DVIEW" "" "TWIST" "0" "")
(COMMAND "SNAPANG" "0")
(COMMAND "ZOOM" "E")
(COMMAND "LTSCALE" "1000")
;Sets Undo Control to On
Undo All
;Quick Saves
._qsave
Thanks in advance.
