Author Topic: 3Doffset and 3Dpoly joint ??  (Read 6177 times)
Re: 3Doffset and 3Dpoly joint ??
« Reply #15 on: November 03, 2005, 06:34:16 PM »
True, but a dark roast has less caffeine.
LE
« Reply #16 on: November 03, 2005, 06:47:44 PM »
My previous post was for the OP.....
LE
« Reply #17 on: November 03, 2005, 09:41:28 PM »
EXPLODE
<pick a 3dpolyline>
-CHANGE
P
E
0
PEDIT
L
J
P
<select other lines, polylines, lwpolylines as desired>
and you have done it.
This is the small test I did:
Command: -ch
CHANGE
Select objects: Specify opposite corner: 2 found
Select objects:
Specify change point or [Properties]: p
Enter property to change [Color/Elev/LAyer/LType/ltScale/LWeight/Thickness]: e
Specify new elevation <varies>: 0
Cannot change elevation of objects with differing Z coordinates.
Command: *Cancel*
Bob Wahr
« Reply #18 on: November 04, 2005, 10:26:04 AM »
EXPLODE
<pick a 3dpolyline>
-CHANGE
P
E
0
PEDIT
L
J
P
Command: -ch
CHANGE
Select objects:
Command: *Cancel*
doh!  My bad.
Bob Wahr
« Reply #19 on: November 04, 2005, 10:27:12 AM »
EXPLODE
FLATTEN
<pick>
PEDIT
L
J
P
Serge J. Gianolla
« Reply #20 on: November 04, 2005, 05:38:56 PM »
Ciao Andrea,
For 3D Offset check Jun 03 here:
http://new.cadalyst.com/code/
Have not tried it!
By the way, tu as ecrit 3D Poly joint, un joint c'est ce qu'on fume :-D but maybe that's what you were after?
deegeecees
« Reply #21 on: November 04, 2005, 05:55:19 PM »
Ciao Andrea,
Have not tried it!
Hey now, I don't think she's a hop head.
LE
« Reply #22 on: November 04, 2005, 06:02:01 PM »
He sounds like a serious person.... I don't think so.
« Reply #23 on: November 04, 2005, 06:02:29 PM »
Who is "she" deeg' ?
.. and I think Serge was joshing about the smoke.
deegeecees
« Reply #24 on: November 04, 2005, 06:05:07 PM »
Oooooops, sorry Andrea. I forgot.  :ugly: Andrea is a common name in the U.S. for females. No offense meant towards you whatsoever.
LE
« Reply #25 on: November 04, 2005, 06:09:14 PM »
Same when using:
Louis
That is not right....   :pissed: ... it is:
Luis
The first one is like the one reporter that works in the Daily Planet with Clark Kent.....
 :lmao:
Bob Wahr
« Reply #26 on: November 04, 2005, 06:13:09 PM »
not quite.  Ms. Lane was Lois, not Louis.  Louis is either a saint or a trumpet player.
LE
« Reply #27 on: November 04, 2005, 06:19:20 PM »
He he.....
1. Not saint et-al
2. I like "Hello dolly"... do not have that talent....
Bob Wahr
« Reply #28 on: November 04, 2005, 06:23:17 PM »
1. Not saint et-al
Sounded nicer than dirty grimy town with absolutely nothing going for it except half a McDonalds sign spanning an oil slick though.
Serge J. Gianolla
« Reply #29 on: November 04, 2005, 06:30:22 PM »
First names are deceptive from country to country. It is only recently i realised Kerry Brown was a guy! [Sorry Kerry - I was more thinking along the line of KAK!] In italian Michele is for males, but a lot of english girls are using same spelling, not double L for their names!
