Code Red => AutoLISP (Vanilla / Visual) => XDRX-API => Topic started by: xdcad on March 29, 2024, 01:48:57 PM
Title: [XDrX-PlugIn(113)] The slide is generated as DWG
Post by: xdcad on March 29, 2024, 01:48:57 PM
(defun c:xdtb_sld2dwg (/ sld)
  (if (setq sld (getfiled (xdrx-string-multilanguage
    "\n选择生成DWG的SLD文件"
    "\nSelect the SLD file to generate DWG"
  "sld"
  4
    (progn (xdrx-slide->dwg sld)
   (xdrx-prompt
       "\n幻灯片生成DWG完毕."
       "\nThe slideshow is generated as DWG."
