Author Topic: New to CAD with a problem.  (Read 7853 times)
Andy L
« on: February 14, 2007, 06:22:11 AM »
I'm trying to copy items from one drawing to another but for some reason it's not happening.
Can select items on one drawing but when I go to paste them on the other one not able to view / see them.
As I said I'm very much a begginer so any help would be appreciated.
Regards
Andy
Krushert
  • FREE BEER Tomorrow!!
Re: New to CAD with a problem.
« Reply #1 on: February 14, 2007, 06:49:59 AM »
First off; Welcome to The Swamp.  :-)
Second; What make and version of CAD do you have?  Some older versions did not have the cut/copy & paste feature.
Third; You should be able to go to EDIT pull down & select the operation you want, just follow the instruction on the command line at the bottom of the screen.  Then go to the drawing you want to paste in and go to the EDIT pull down menu and select the paste operation you want.
Fourth; if that fails, look up the command WBLOCK (that is if you are running an Autodesk Product) in help and follow the instructions.   A tried and true meathod.
hudster
« Reply #2 on: February 14, 2007, 06:54:59 AM »
Are you maybe copying objects on a layer which could be frozen off on your drawing?
I've done this before and it can be confusing.
jonesy
  • SuperMod
« Reply #3 on: February 14, 2007, 07:37:36 AM »
Welcome to theSwamp Andy
Another thought, once pasted, did you zoom extents?
Andy L
« Reply #4 on: February 14, 2007, 07:50:56 AM »
Running on AutoCAD 2006....thanks for your help / comments .....I'll give them a try and see if it fixes the problem.
At this rate i think you will be seeing a lot more of me :-)
Birdy
« Reply #5 on: February 14, 2007, 08:34:01 AM »
Good! Welcome to the Swamp Andy.
This place is full of some of the best autocad experts on the planet.  (Maybe someday I'll be one of them.)
Plenty of help to be had here.
hendie
« Reply #6 on: February 14, 2007, 08:43:14 AM »
wasn't there a known issue with cut'n'paste in 2006 and they had to fix it with a service pack ? or am I off in never never land again
hudster
« Reply #7 on: February 14, 2007, 08:50:00 AM »
2007 had a cut and paste issue, but while it pastes, but no one else could copy and paste from the drawing, so this could be the problem if the drawing originated on a  machine with an unpatched 2007 version installed.
Andy L
« Reply #8 on: February 14, 2007, 09:33:51 AM »
This may be the answer as the drawing I'm working on came from one of our customers who got it from one of his customers etc, etc, etc
hudster
« Reply #9 on: February 14, 2007, 09:53:40 AM »
If you need to get the stuff, you could post it here and i'll save it for you so you can cut and paste from it.
pmvliet
« Reply #10 on: February 14, 2007, 10:23:42 AM »
Just make sure you aren't nekkid or something  :-D
let us know what you find out.
Pieter
CADaver
« Reply #11 on: February 14, 2007, 12:51:41 PM »
If you're trying "drag-n-drop", make sure PICKFIRST is on.
Greg B
  • Tell me a Joke!
« Reply #12 on: February 14, 2007, 04:56:52 PM »
And a couple other CAD programs as well, but those AutoCAD people won't admit it.
Josh Nieman
« Reply #13 on: February 14, 2007, 05:04:22 PM »
*looks around*
...I LIKE SOLIDWORKS!  seriously though... I do
*runs*
Birdy
« Reply #14 on: February 14, 2007, 06:49:45 PM »
This place is full of some of the best autocad CAD experts on the planet.  (Maybe someday I'll be one of them.)
My humblest apologies Greg.  Sometimes I forget my manners.
and in my (somewhat limited) experience, SolidWorks is. period.  (I'm agreeing with you Josh!)
...but I'm not gonna get into a debate on what the meaning of the word is        is.
