Author Topic: Exporting Sheet Files to Autocad  (Read 2314 times)
MSTG007
« on: January 25, 2016, 04:36:52 PM »
Has anyone had any problems exporting sheet files to generic AutoCAD DWG? Lately when we try to export a sheet file that has several xrefs (Without Civil3D Data) and all the Civil3D Data is Referenced inside the sheet; it bombs out. So we have to bind each file into the sheet file until we find the one that is messed up and audit, etc.
The other question I have to this is, when you export how can you just export the entities objects that are on and not those that are off or frozen? I know you can do that by WBLOCK but I do not know how that would work with a title block within paperspace.
Civil3D 2020
Re: Exporting Sheet Files to Autocad
« Reply #1 on: January 25, 2016, 04:49:00 PM »
I found that the XREF causing the issue, had issue(s) causing the problem.
Fix that XREF and the export to AUTOCAD should then function as expected.
MSTG007
« Reply #2 on: January 25, 2016, 05:30:30 PM »
Yup. That's what I thought. Bummers
Civil3D 2020
« Reply #3 on: January 25, 2016, 05:44:52 PM »
Check out the XREF that is causing it to bomb-out....something should pop up as (wrong, bad, off) through audit/recover etc.
It can even be a nested/lost or orphaned file issue
