Author Topic: Highlighting entities  (Read 2629 times)
  • Custom Title
« on: February 01, 2005, 07:44:00 AM »
Here's a simple method for highlighting user selected entities.
(defun c:hle1 (/ ent ent_type lst_of_ents)
  (while (setq ent (car (entsel "\nPick something <enter> to quit: ")))
         ;; highlight the selected entity
         (redraw ent 3)
         (setq ent_type (cdr (assoc 0 (entget ent)))    ; extract entity type
               lst_of_ents (cons ent lst_of_ents) ; create a list of entities selected
         (princ (strcat "\nAdded " ent_type " to the list"))
         ); while
  ;; un-highlight the entities
  (foreach item lst_of_ents (redraw item 4))
ImaJayhawk
« Reply #1 on: February 01, 2005, 10:28:45 AM »
Why not use
      ;convert object to vla object
      (setq sor (vlax-ename->vla-object (car ent)))
      ;set highlight to true for the selected object
      (vla-highlight sor "true")
and
(vla-highlight sor "false")
--ImaJayhawk
« Reply #2 on: February 01, 2005, 11:12:12 AM »
Here is another, not sure where i got the code.
(if ss
    (setq num (sslength ss) i -1)
       (while (< (setq i (1+ i)) num)
         (setq vlaobj (vlax-ename->vla-object (ssname ss i)))
         (vla-Highlight vlaobj :vlax-true)
         (vla-update vlaobj)
