Code Red => VB(A) => Topic started by: Adesu on February 01, 2007, 01:48:45 AM
Hi Alls,
I'm "NOT" expert in vba,very little understand about vba.
anyone have code in vba to send email,as figure I want that code display (not in dialog box) in command prompt,to ask to user first "send to" second "title the email" and then "body of email".
I very appreaciated for this help,thanks.
Have you seen: http://discussion.autodesk.com/thread.jspa?messageID=409179
Hi swain,
I got trouble to load it,look at attach file'
I know I've to disappoint you on the simplicity
but instead of using Outlook and Mapi, you can also use the CDO object(Late Bound) .
mail send through this object doesn't show any dialogs nor warnings (if the authorization is set correctly)
nor will the email show up in outlook or any other mail client.
I suggest You google around to find code samples on the CDO object.
Hi Dnereb,
Thanks for your suggest,I would to try it.
