OK, the Extract2d will take a Featureline with arcs and elevations and correctly convert it to a 2d polyline with arcs that mimics the original featureline. I had thought Sinc had added the ability to take a 3dpoly and determine if a 2d poly could be created with arcs, but it's not doing so. However, since it sounds like you want to take a F/L and get a 2dpoly from it, this command would do exactly that.
