Detail Indicator Tool
GDF:
Alan
I like you routine...
Here is what I use (options include making it a block or a group for the final bubble).
--- Code: ---;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
;;;;;;;;;;;;;;;;;;;;;;;;;;;;; Block or Group Functions ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(defun ARCH:BLOCK-GROUP (/ yn)
(defun ARCH_BLOCK ()
(command
"-block"
(princ ARCH#_NIC)
(getvar "lastpoint")
(princ ARCH#SSET)
(command "-insert" (princ ARCH#_NIC) (getvar "lastpoint") "" "" ""))
(defun ARCH_GROUP ()
(setq ARCH#_NIC "*")
;;anon group
(command "-group" "" (princ ARCH#_NIC) "" (princ ARCH#SSET) ""))
(initget "B G")
(setq yn
(getkword
"\n* Select Creation Type <default is group>: <B>lock <G>roup <enter> for group*"))
(cond ((= yn "B") (ARCH_BLOCK))
((or (/= yn "B") (= yn "G")) (ARCH_GROUP)))
(setq ARCH#_NIC nil
ARCH#SSET nil)
(princ))
(defun ARCH:BLOCK- ()
(command
"-block"
(princ ARCH#_NIC)
(princ ARCH#SSET)
(setq ARCH#_NIC nil
ARCH#SSET nil)
(princ))
(defun ARCH:GROUP- ()
;;anon group
(setq ARCH#_NIC nil
ARCH#SSET nil)
(princ))
;;;;;;;;;;;;;;;;;;;;;;;;;;; Raddom Generator Number ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(defun ARCH:RAND*NO ()
(setq *NO (rtos (getvar "CDATE") 2 16)
*NO (substr *NO 14 3)
;;3
(princ))
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; Detail Bubble ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(defun C:RPD (/ efat efsht ltag angx *NO SB pdend pdend2 scf pdtx pd1 pdtx angt pickdir
ango pdend ptb1 ptb2 ptb3 ptb4 rad)
(if (= ARCH#BLKX nil)
(ARCH:BLKNAM "SYMBUB" (strcat ARCH#CUSF "SYMS/")))
(setq scf (getvar "dimscale"))
;(ARCH:CUSTOM_LAYERS-SYMB) my custom layer creator
(setq ARCH#SSET (ssadd))
(setq rad (* 0.375 (getvar "dimscale")))
;;(setvar "PLINEWID" (* (getvar "dimscale") 0.0125))
;;0.015625
(setq efat (getstring t (strcat "\n* Enter the Reference Number <" ARCH#DTLN ">:")))
(setq efsht (getstring t (strcat "\n* Enter the Sheet Number <" ARCH#SHTN ">:")))
(cond ((/= efat "") (setq ARCH#DTLN efat))
((= efat "") (setq efat ARCH#DTLN)))
(cond ((/= efsht "") (setq ARCH#SHTN efsht))
((= efsht "") (setq efsht ARCH#SHTN)))
(setvar "osmode" 0)
(setq ptb1 (getpoint "\n* Pick upper left hand corner point *"))
(setq ptb3 (getcorner "\n* Pick opposite corner point *" ptb1))
(setq ptb2 (list (car ptb1) (cadr ptb3)))
(setq ptb4 (list (car ptb3) (cadr ptb1)))
(command "pline" ptb1 ptb2 ptb3 ptb4 "c")
(setq ARCH#SSET (ssadd (entlast) ARCH#SSET))
(command "fillet" "r" rad "")
(command "fillet" "p" "l")
(command "change" "last" "" "properties" "lt" "HIDDEN" "c" "2" "")
(setvar "orthomode" 0)
(setvar "osmode" 512)
(setq pd1 (getpoint "\n* Pick along BUBBLE ... for the text location *"))
(setq pdtx (getpoint pd1 "\n* To Point *"))
(setq angt (angle pd1 pdtx))
(setvar "orthomode" 1)
(setq pickdir (getpoint pdtx "\n* Pick Direction *"))
(setq ango (angle pdtx pickdir))
(setq pdend (polar pdtx ango (* 0.25 (getvar "dimscale"))))
(setvar "osmode" 0)
(command "PLINE" pd1 pdtx pdend "")
(command "change" "last" "" "properties" "c" "2" "")
(setvar "cmdecho" 0)
(command
"insert"
(strcat ARCH#CUSF "SYMS/" "SYMBUB")
"ps"
SCF
SCF
efat
(strcase efsht))
(setq pdend (polar pdtx ango (* 0.5 SCF)))
(command "PLINE" (getvar "lastpoint") pdend "")
(ARCH:RAND*NO)
(setq ARCH#_NIC (strcat "SYMRPD-" *NO))
(ARCH:BLOCK-GROUP)
(command "fillet" "r" "0")
(prompt "\n* Detail Rectangular Bubble Mark completed *"))
--- End code ---
Gary
CAB:
Nice one Gary.
Thanks for sharing.
VVA:
Probably so will be more correct
--- Code: ---(setq p1 (getpoint (strcat "\nPick corner away from tag or [Textsize/Plinewidth]:TH->"
(rtos *MyTextsize 2 2) " Plw->"(rtos *MyPLWidth 2 2))))
--- End code ---
Text [Textsize/Plinewidth]
instead [Textsize\Plinewidth]
CAB:
I often forget which slash is needed to enable the choices in the right click menu.
I think that's because I never use the right click feature. 8-)
CAB:
Had some spare time so I added a twist to the pick point routine.
Code updated in the first post.
Also I removed the fillet for now.
<edit: added fillets back in>
Navigation
[0] Message Index
[*] Previous page
Go to full version
