CAD Forums => CAD General => The Third Dimension => Topic started by: jesseinlp on October 21, 2010, 09:18:19 AM
Does anyone out there know if it is possible to View/Reference/Convert Bentley Autoplant models into Smartplant 3D?
If so has anyone tried it?
Plant design software has a history of being almost (but not entirely) incompatible with each other. Even if you do find a method you will likely still be tracing center lines. Try for a PDF export/import for starters.
