C++ to lisp
Kerry:
pedroantonio124,
Which AutoCAD build are you using ?
pedroantonio124:
AutoCad 2014
irneb:
--- Quote from: pedroantonio124 on December 08, 2014, 04:40:17 AM ---Hello irneb,
Thanks for your help :-)
Unfortunately, I still receive the wrong result with the lisp code.
Maybe I can find the mistake if I know the result of every line.
Could you let me the C # run through over again code? Please
With a Console.WriteLine for every line.
--- End quote ---
Rather than a WriteLine per line ... just get hold of a DotNet IDE and debug step through it.
You can get a free IDE, either of these would do:
* http://www.visualstudio.com/en-us/products/visual-studio-express-vs.aspx
* http://www.icsharpcode.net/opensource/sd/
Kerry:
You want fries with this ?
--- Code - C#: ---using System;using System.Collections.Generic;using System.Globalization;using System.Linq;using System.Text;using System.Threading.Tasks; namespace ToLatLon{ internal class Program { private static void Main(string[] args) { Console.Write("\n UTM to LatLon test.\n From theSwamp\n http://www.theswamp.org/index.php?topic=48330.0" ); Console.Write("\n\nEnter utmX value : " ); double utmX = double.Parse(Console.ReadLine()); Console.Write("\nEnter utmY value : " ); double utmY = double.Parse(Console.ReadLine()); Console.Write("\nEnterutmZone value : " ); string utmZone = Console.ReadLine(); ToLatLon(utmX, utmY, utmZone); Console.ReadKey(); } public static void ToLatLon(double utmX, double utmY, string utmZone) { double latitude = 0; double longitude = 0; bool isNorthHemisphere = utmZone.Last() >= 'N'; var diflat = -0.00066286966871111111111111111111111111; var diflon = -0.0003868060578; var zone = int.Parse(utmZone.Remove(utmZone.Length - 1)); var c_sa = 6378137.000000; var c_sb = 6356752.314245; var e2 = Math.Pow((Math.Pow(c_sa, 2) - Math.Pow(c_sb, 2)), 0.5)/c_sb; Console.WriteLine("\ne2:\t " + e2.ToString()); var e2cuadrada = Math.Pow(e2, 2); Console.WriteLine("\ne2cuadrada:\t " + e2cuadrada.ToString()); var c = Math.Pow(c_sa, 2)/c_sb; Console.WriteLine("\nc:\t " + c.ToString()); var x = utmX - 500000; Console.WriteLine("\nx:\t " + x.ToString()); var y = isNorthHemisphere ? utmY : utmY - 10000000; Console.WriteLine("\ny:\t " + y.ToString()); var s = ((zone*6.0) - 183.0); Console.WriteLine("\ns:\t " + s.ToString()); var lat = y/(6366197.724*0.9996); // Change c_sa for 6366197.724 Console.WriteLine("\nlat:\t " + lat.ToString()); var v = (c/ Math.Pow(1 + (e2cuadrada*Math.Pow(Math.Cos(lat), 2)), 0.5))* 0.9996; Console.WriteLine("\nv:\t " + v.ToString()); var a = x/v; Console.WriteLine("\na:\t " + a.ToString()); var a1 = Math.Sin(2*lat); Console.WriteLine("\na1:\t " + a1.ToString()); var a2 = a1*Math.Pow((Math.Cos(lat)), 2); Console.WriteLine("\na2:\t " + a2.ToString()); var j2 = lat + (a1/2.0); Console.WriteLine("\nj2:\t " + j2.ToString()); var j4 = ((3*j2) + a2)/4.0; Console.WriteLine("\nj4:\t" + j4.ToString()); var j6 = (5*j4 + a2*Math.Pow((Math.Cos(lat)), 2))/3.0; // saque a2 de multiplicar por el coseno de lat y elevar al cuadrado Console.WriteLine("\nj6:\t " + j6.ToString()); var alfa = (3.0/4.0)*e2cuadrada; Console.WriteLine("\nalfa:\t " + alfa.ToString()); var beta = (5.0/3.0)*Math.Pow(alfa, 2); Console.WriteLine("\nbeta:\t " + beta.ToString()); var gama = (35.0/27.0)*Math.Pow(alfa, 3); Console.WriteLine("\ngama:\t " + gama.ToString()); var bm = 0.9996*c*(lat - alfa*j2 + beta*j4 - gama*j6); Console.WriteLine("\nbm:\t " + bm.ToString()); var b = (y - bm)/v; Console.WriteLine("\nb:\t " + b.ToString()); var epsi = ((e2cuadrada*Math.Pow(a, 2))/2.0)* Math.Pow((Math.Cos(lat)), 2); Console.WriteLine("\nepsi:\t " + epsi.ToString()); var eps = a*(1 - (epsi/3.0)); Console.WriteLine("\neps:\t " + eps.ToString()); var nab = (b*(1 - epsi)) + lat; Console.WriteLine("\nnab:\t " + nab.ToString()); var senoheps = (Math.Exp(eps) - Math.Exp(-eps))/2.0; Console.WriteLine("\nsenoheps:\t " + senoheps.ToString()); var delt = Math.Atan(senoheps/(Math.Cos(nab))); Console.WriteLine("\ndelt:\t " + delt.ToString()); var tao = Math.Atan(Math.Cos(delt)*Math.Tan(nab)); Console.WriteLine("\ntao:\t " + tao.ToString()); longitude = (delt/Math.PI)*180 + s; latitude = (((lat + (1 + e2cuadrada*Math.Pow(Math.Cos(lat), 2) - (3.0/2.0)*e2cuadrada*Math.Sin(lat)*Math.Cos(lat)* (tao - lat))*(tao - lat)))/Math.PI)*180; // era incorrecto el calculo Console.WriteLine("\nLatitud:\t " + latitude.ToString() + "\nLongitud:\t " + longitude.ToString()); } }}
irneb:
Damn ... you're much to quick!
Anyhow, if you don't want to install anything new, you could use IDEone: http://ideone.com/5irS8R
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
