LEECOOL!Processing speed is very fast,But the results of processing, integer bit behind" . 00", but the calculation results have no effect.
LEE,I mean, if sj.dat there are digital ( for example: 10), your program running results was "10", and in sjold.dat format should be "10.00", but this time I have to deal with a lot of data format requirements is not very strict.Thanks!
Quote from: Lee Mac on December 04, 2011, 06:53:26 PMOh from your screenshot, I see what you mean about the space - it only displays up to line 35 for me [using FF8.0 W7], which is similar to the existing code panes so I couldn't see what you were getting at initially.Odd, I looked at it with FF8.0+Win7. I also upgraded today to 8.0.1 and it still doesn't condense the code. Even 35 lines is a lot.
FWIW, using the 'Core' Swamp theme (the old theme), I see all 101 lines of code displayed - also, the font-size is pretty small.
Quote from: Lee Mac on December 16, 2011, 07:21:12 AMFWIW, using the 'Core' Swamp theme (the old theme), I see all 101 lines of code displayed - also, the font-size is pretty small. Don't use the Core Theme. That's an easy one.
