Author Topic: Change object/entity line type scale by layer name inside nested blocks  (Read 2809 times)
tive29
Googles this lisp sometime back. Was by Tharwat & Kent Cooper.
This lisp changes the linetype scale of the entities & object base on layername. But It does not change those that is inside nested blocks.
I now need it to change those inside nested blocks too.
Need help with the changes to include objects & entities inside nested blocks.
Thank you
(defun c:test (/ ly ss)
  ;; Tharwat 06.May.2014  ;;
  ;; altered for list-of-lists approach by Kent Cooper 14 May 2014 ;;
  (setq ly '(("Layer1" 0.5) ("Layer2" 0.75) ("Layer3" 1.5)))
    (setq ss
      (ssget "_X"
        (list
          '(0 . "CIRCLE,ARC,ELLIPSE,*LINE,RAY,HATCH,REGION")
            ;; [added RAY,HATCH,REGION (people should avoid Hatching on non-continuous-linetype
            ;; Layers, but they do honor linetypes and linetype scale) -- any other possibilities? Leaders
            ;; and Dimensions honor linetypes, but for some reason not linetype scale.]
          (cons 8 (apply 'strcat (mapcar '(lambda (u) (strcat (car u) ",")) ly)))
        ); list
      ); ssget
    ); setq
    ( (lambda (i / sn v)
        (while (setq sn (ssname ss (setq i (1+ i))))
          (if (vlax-write-enabled-p (setq v (vlax-ename->vla-object sn)))
            (vla-put-linetypescale v (cadr (assoc (cdr (assoc 8 (entget sn))) ly)))
          ); if
        ); while
      ); lambda
      -1
  ); if
); defun
Try this:
  1. (defun c:test (/ a b ly ss u)
  2.   ;; Tharwat 06.May.2014  ;;
  3.   ;; altered for list-of-lists approach by Kent Cooper 14 May 2014 ;;
  4.   (setq ly '(("Layer1" 0.5) ("Layer2" 0.75) ("Layer3" 1.5)))
  5.   (if (setq ss (ssget "_X"
  6.                       (list '(0 . "INSERT,CIRCLE,ARC,ELLIPSE,*LINE,RAY,HATCH,REGION")
  7.                             ;; [added RAY,HATCH,REGION (people should avoid Hatching on non-continuous-linetype
  8.                             ;; Layers, but they do honor linetypes and linetype scale) -- any other possibilities? Leaders
  9.                             ;; and Dimensions honor linetypes, but for some reason not linetype scale.]
  10.                             (cons 8 (apply 'strcat (mapcar '(lambda (u) (strcat (car u) ",")) ly)))
  11.                       )                 ; list
  12.                )                        ; ssget
  13.       )                                 ; setq
  14.     ((lambda (i / e sn tmp v)
  15.        (while (setq sn (ssname ss (setq i (1+ i))))
  16.          ;; RJP - 5.5.2017 removed vl & added nested items
  17.          (cond ((= "INSERT" (cdr (assoc 0 (entget sn))))
  18.                 (setq e (tblobjname "block" (cdr (assoc 2 (entget sn)))))
  19.                 (while (setq e (entnext e))
  20.                   (if (= "INSERT" (cdr (assoc 0 (entget e))))
  21.                     (setq e (tblobjname "block" (cdr (assoc 2 (entget e)))))
  22.                   )
  23.                   (and (setq tmp (cadr (assoc (cdr (assoc 8 (entget e))) ly)))
  24.                        (entmod (append (entget e) (list (cons 48 tmp))))
  25.                   )
  26.                 )
  27.                )
  28.                ((setq tmp (cadr (assoc (cdr (assoc 8 (entget sn))) ly)))
  29.                 (entmod (append (entget sn) (list (cons 48 tmp))))
  30.                )
  31.          )
  32.        )                                ; while
  33.      )                                  ; lambda
  34.       -1
  35.     )
  36.   )                                     ; if
  37.   (princ)
  38. )
« Last Edit: May 08, 2017, 09:33:55 AM by ronjonp »
tive29
Hi ronjonp. It works for block 1 level deep only. Please include nested block.
tive29
Hi ronjonp. Any luck for the lisp to include nested blocks?
Try the code above.
tive29
Try the code above.
Hi ronjonp. Finally got a chance to try it for my work. But unfortunately, the layers inside the blocks & nested blocks did not change the linestype scale. Only the ones not a block are changed.
I attached my drawing for your reference.
This is a much simpler approach:
  1. (defun c:foo (/ l tmp)
  2.   (setq l '(("LAYER1" . 0.5) ("LAYER2" . 0.75) ("LAYER3" . 1.5)))
  3.     (vlax-for b a
  4.       (if (setq tmp (cdr (assoc (strcase (vla-get-layer b)) l)))
  5.         (vl-catch-all-apply 'vla-put-linetypescale (list b tmp))
  6.       )
  7.     )
  8.   )
  9.   (princ)
  10. )
tive29
Thanks ronjonp. Its working now  :smitten:
Glad to help :)
