CAD Forums => CAD General => Topic started by: dbsf on January 05, 2009, 11:02:38 AM
So there is three of us in the office that have forgotton what mjfarrell taught us last winter in a week long seminar.
What style needs to be edited in C3D to remove the purple circles from the cross sections?
Thanks in advance.
Hi dbsf, welcome to the Swamp! We have an area specifically for C3D/LDT questions, and that is where MJF can usually be summoned quite quickly. Go to the LandLubbers forum: http://www.theswamp.org/index.php?board=10.0
To answer your question, those circles are found in the Code Set styles under the Points section.
Thanks!
you might want to create that code set such thatthose Circles are both Still ON, and of a reasonable size to work with in your model space views, and then OFF or Frozen in your viewports
