Author Topic: remove line feeds from a string  (Read 1591 times)
poncelet
« on: October 01, 2011, 09:29:42 AM »
Hello,
Is there a way to remove line feeds (empty lines) with regex?
output = Regex.Replace(output, "\r{2}", Environment.NewLine)
Code above doens't work  :-(
gile
  • Marseille, France
Re: remove line feeds from a string
« Reply #1 on: October 01, 2011, 10:26:07 AM »
This may work :
output = Regex.Replace(output , "\n{2}", "\n");Or this (depends on the output string):
output = Regex.Replace(output , "(\r\n){2}", "\n");
But it would be easier to reply if give some more precision, i.e. an example of 'output' string, or how do you get it...
« Last Edit: October 01, 2011, 10:45:22 AM by gile »
poncelet
« Reply #2 on: October 01, 2011, 10:35:26 AM »
I tried it but it doesn't remove line feeds.
I import an ascii file with coordinates:
1   475830.758   4199125.634
2   475834.777   4199116.911
3   475840.666   4199101.86
4   475836.718   4199110.199
i can remove them with this code:
        Dim length As Long
        While length <> text.Length
            length = text.Length
            text = text.Replace(Environment.NewLine & Environment.NewLine, Environment.NewLine)
        End While
        If Microsoft.VisualBasic.Right(text, 1) = Chr(10) Then
            text = text.Remove(text.Length - 1)
        End If
        Return text
but i would like to use regex
gile
  • Marseille, France
« Reply #3 on: October 01, 2011, 10:51:45 AM »
Look at the second expression in my  first post, it may work with a string imported from an ascii file where a new line consist in a carriage return char plus a a new line char ("\r\n").
poncelet
« Reply #4 on: October 01, 2011, 10:55:19 AM »
I'm going to try this too
Solution:
output = Regex.Replace(output, "[\r\n]+", Environment.NewLine) :lol:
I was trying for hours to find solution
Thank you gile!
Suddenly i got more than one options (haha!)
