Code Red => AutoLISP (Vanilla / Visual) => Topic started by: CatDance on August 22, 2021, 04:25:28 AM
(command "imageclip" iEn
"n" "p" cPtLt
I am trying to clip a square image (jpeg image) into a circular shape.
It did not clip the image and just exited the command line.
How to pass a point list to the command line ?
Perhaps the IMAGECLIP command only accepts 2d points (didn't try). But you need to close the command with "" [enter].
My advise:
If you're using a MAC, first draw a clipping boundary with the POLYGON command and then use IMAGECLIP.
If you're using Windows: Try the CLIPIT command (from express tools).
If you look closely clipit makes a polygon boundary.
