Hi ye all, newb here just reading through and learning bits of info...
ronjonp you mentioned "FYI....I learned today that vanilla Autocad 2002 will insert .sid files."
I used vanila "AutoCAD" and use SID maps , but my 2002 dosn't support the files with ext .SID. Is there a add on for this? How do I insert these maps into AutoCAD?
I used a DOS based decorder called: Mrsiddecoder.exe to convert MrSID maps into jpgs to insert into AutoCAD and this is working well for my needs. But will be very interested in inserting SID maps into 2002.
