Author Topic: reading csv files 1 cell at a time  (Read 3076 times)
andrew_nao
« on: March 26, 2008, 02:34:50 PM »
anyone have any code they can share on reading cells in a csv file?
I have code that will read the whole row but im looking for a way to read each cell individually and set a variable to it
something along the lines of
row 1 cell a is hello
row 1 cell b is world
(setq 1a = "row1" "cell a")
(setq 1b = "row1" "cell b")
(princ 1a)
(princ 1b)
hope this is understandable
Re: reading csv files 1 cell at a time
« Reply #1 on: March 26, 2008, 03:23:18 PM »
If you are reading row at a time the data should look like this:
(setq rowData '("Cell 1" "Cell 2" "Cell 3" .....))
to get the cell info use this:
(setq cellData (nth 1 rowData))
and you will get this: "Cell 2"
(setq cellData (nth 0 rowData))
and you will get this: "Cell 1"
gile
  • Marseille, France
« Reply #2 on: March 26, 2008, 04:36:51 PM »
Here's a way, the read-csv routine returns an association list like: (("A1" . value_1) ("A2" . value_2) ...)
Using example:
(setq cells (read-csv (getfiled "Choose a file" "" "csv" 0)))
to get the C2 cell value:
(cdr (assoc "C2" cells))
;; Num2Alpha
;; Converts Number into Alpha string
;; Arguments:
;;   Num = Number to convert
;; Syntax example: (Num2Alpha 731) = "ABC"
(defun num2alpha (num / r)
  (if (< num 27)
    (chr (+ 64 num))
    (if (= 0 (setq r (rem num 26)))
      (strcat (num2alpha (1- (/ num 26))) "Z")
      (strcat (num2alpha (/ num 26)) (chr (+ 64 r)))
;; STR2LST
;; Converts a string with separator into a list of strings
;; Arguments
;;   str = the string
;;   sep = the separator pattern
;; Syntax example: (str2lst "A,B,C" ",") = ("A" "B" "C")
(defun str2lst (str sep / pos)
  (if (setq pos (vl-string-search sep str))
    (cons (substr str 1 pos)
  (str2lst (substr str (+ (strlen sep) pos 1)) sep)
    (list str)
;; READ-CSV
;; Reads a csv file and returns an association list (("A1" . value_1) ("A2" . value_2) ...)
;; Argument
;;   path = the file complete path
;; Syntax example: (read-csv "C:\\Temp\\test.csv")
(defun read-csv (path / file cell row col lst)
  (and
    (setq file (open path "r"))
    (setq row 1)
    (setq col 0)
    (while (setq line (read-line file))
      (setq lst (cons
  (mapcar
    (function
      (lambda (x)
(cons
  (strcat (num2alpha (setq col (1+ col))) (itoa row))
  x
    (str2lst line ",")
  lst
    row (1+ row)
    col 0
    (close file)
  (apply 'append (reverse lst))
« Last Edit: March 26, 2008, 06:17:05 PM by gile »
« Reply #3 on: March 26, 2008, 05:01:18 PM »
This has little error checking, but returns a specific row,cell from a specified file.
usage is
(getCell 3 10 "C:\\MyDocs\\ThisFile.csv")
returns cell 3 10 i.e. C10 out of the specified file
If the cell does not exist it crashes
(defun getCell (rowX columnY file / begin count fn index row rval)
  (setq fn    (open file "r")
index 0
  (while (< index rowX)
    (setq row (read-line fn)
  index (1+ index)
  (close fn)
  (setq index 1
begin 1
count 1
  (while (< index (+ (strlen row) 1))
    (if (= (substr row index 1) ",")
      (if (= count columnY)
(if (= begin index)
  (setq rval "")
  (setq rval (substr row begin (- index begin))
(setq count (1+ count)
      begin (1+ index)
      index (1+ index))
      (setq index (1+ index))
  (if (= rval nil)
    (setq rval (substr row begin (- (strlen row) begin)))
  rval
gile
  • Marseille, France
« Reply #4 on: March 26, 2008, 06:35:16 PM »
Another one, same usage as Keith's.
It returns nil for over range row or column.
;; STR2LST
;; Transforms a string with separator into a list of strings
;; Arguments
;;   str = the string
    (list str)
;; GET-CELL
;; Returns the cell value of a csv file
;; Arguments
;;   path: the complete file path
;;   row: the row number
;;   col: the column number
;; Syntax example: (get-cel "C:\\Temp\\test.csv" 2 3) = "C2" cell value
(defun get-cell (path row col / file line lst sub)
  (and
      (setq lst (cons (str2lst line ",") lst))
    (close file)
  (if (and lst (setq sub (nth (1- row) (reverse lst))))
    (nth (1- col) sub)
andrew_nao
« Reply #5 on: March 27, 2008, 09:58:13 AM »
this is what im looking for however im doing something wrong
could you please give me some feedback on what im doing wrong?
this is what i have so far
(defun filetolist(f / *list* ltext f*1)
(setq *list* '())
(setq f*1 (open f "r"))
(while (setq ltext (read-line f*1))
(setq *list* (cons ltext *list*))
(close f*1)
(setq *list* (reverse *list*))
(setq newlist (filetolist "c:\\TEST.csv"))
(setq line1 (cons 1 (nth 0 newlist)))
(setq ROWDATA '(LINE1))
(setq CELLDATA (nth 0 ROWDATA))
(PRINC CELLDATA)
(PRINC)
« Reply #6 on: March 27, 2008, 11:03:24 AM »
Test this:
(defun filetolist (f / *list* ltext f*1)
  (close f*1)
  (reverse *list*) ; return the list
;;  note that nth is base zero, first item is 0 and not 1
(setq RowNum 3) ; get row 3 as an example, need error check incase there is no row 3
(setq lineData (nth RowNum newlist))
(setq ColNum 2) ; example, need error check incase there is no column data
(setq CELLDATA (nth ColNum lineData))
(PRINC CELLDATA)
(PRINC)
PS This code need refinement & error checking & more help.
So post your next version so these items can be addressed.
andrew_nao
« Reply #7 on: March 27, 2008, 02:24:09 PM »
i appreciate your time and help
I dont know how to do error checking so that might be a problem
because when i load the code you posted it i get
Loading...; error: bad argument type: consp "hello,world,hello,world"
« Reply #8 on: March 27, 2008, 04:15:57 PM »
Give this a test drive.
(defun c:test (/ FullFileName RowNum ColNum FileName NewList LineData
               CellData filetolist sparser)
  (defun filetolist (fln / lst ltext fn)
    (if (setq fn (open fln "r"))
        (while (setq ltext (read-line fn))
          (setq lst (cons ltext lst))
        (close fn)
    (reverse lst)                       ; return the list
  ;;  parser by CAB single character delim, match ","
  (defun sparser (str delim / ptr lst)
    (while (setq ptr (vl-string-search delim str))
      (setq lst (cons (substr str 1 ptr) lst))
      (setq str (substr str (+ ptr 2)))
    (reverse (cons str lst))
  ;; So let user use base 1 & we will subtract 1
  (initget 7)
  (setq RowNum (getint "\nEnter the Row Number. "))
  (initget 7)
  (setq ColNum (getint "\nEnter the Cell Number. "))
  (setq FileName "c:\\TEST.csv")
  ;;  Open & Read File, attempt to get cell data
    ((null (setq FullFileName (findfile FileName)))
     (princ "\nFile not found.")
    ((null (setq newlist (filetolist FullFileName)))
     (PRINC "\nNo data found in file.")
    ((null (setq lineData (nth (1- RowNum) newlist)))
     (PRINC "\nNo row data found in file.")
    ;;  seperate row data into cells & get the cell
    ((null (setq CELLDATA (nth (1- ColNum) (sparser LineData ","))))
     (PRINC "\nNo column data found in row.")
    (t ; if we are here all worked OK
     (princ CellData))
  (PRINC)
andrew_nao
« Reply #9 on: March 28, 2008, 08:40:21 AM »
thanks
but its not working
Loading...; error: bad argument type: numberp: nil
« Reply #10 on: March 28, 2008, 08:59:31 AM »
Download the attached lisp, run it.
If an error occurs copy the output from the command line & post it here.
andrew_nao
« Reply #11 on: March 28, 2008, 10:05:29 AM »
that worked, what was done differently?
ill have to go back and how you did that.
your help is much appreciated
« Reply #12 on: March 28, 2008, 10:28:18 AM »
All I added was an error subroutine.
I suspect when you copied the lisp some of it was not copied.
It happens a lot, so by attaching the lisp file I eliminated the chance for that error.
dubb
« Reply #13 on: October 25, 2016, 03:26:11 PM »
Excuse my lack of knowledge on how this script works. I would like to use this script to also parse an entire column or row instead of a single cell. :smitten:
        (close fn)
  (initget 7)
  (initget 7)
     (princ CellData))
  (PRINC)
