Where did you find variable lst defined?
Have you tried :Code - Auto/Visual Lisp: [Select]
(defun kpblc (obj-lst / adoc name selset)
(setq adoc (vla-get-activedocument (vlax-get-acad-object))
name "TempSelSet"
) ;_ end of setq
(vl-catch-all-apply (function (lambda () (vla-delete (vla-item (vla-get-selectionsets adoc) name))))
) ;_ end of vl-catch-all-apply
(setq selset (vla-add (vla-get-selectionsets adoc) name))
(vla-additems selset
(vlax-make-variant
(vlax-safearray-fill (vlax-make-safearray vlax-vbobject (cons 0 (1- (length obj-lst)))) obj-lst)
) ;_ end of vlax-make-variant
) ;_ end of vla-additems
selset
) ;_ end of defun
@Grrr1337:
I understand what you are doing there: working around the missing ObjectName property. But the selection set object has some unique methods, checking for those would be more straightforward.
Have you tried :Quote(defun kpblc (obj-lst / adoc name selset)
name "TempSelSet"
) ;_ end of setq
(vlax-make-variant
selset
) ;_ end of defun
