Author Topic: Civil 3D | Raise/Lower by Reference?  (Read 4591 times)
BlackBox
« on: May 03, 2016, 05:17:10 PM »
I feel like I have to be missing something simple... How does one Raise/Lower a Feature Line by SURFACE Reference? :?
As example:
I have a Feature Line that I've graded to be a typical lot line, and want to raise/lower the entire Feature Line by the vertical distance between the start point (front of lot) to my Corridor's Surface (at R/W).
Cheers
Re: Civil 3D | Raise/Lower by Reference?
« Reply #1 on: May 03, 2016, 05:34:53 PM »
it works exactly the opposite of how one thinks that it would....
so one must select the feature line
select command raise lower by reference
then select the point you want to reference...
and then decide whether you are using an elevation difference or grade or slope....
you will get it wrong at least three times....before you get it right
« Reply #2 on: May 03, 2016, 05:38:07 PM »
oh, and lastly it must e a surface cogo point if you are trying to reference a surface
it's more fun in bizzaro C3D!
BlackBox
« Reply #3 on: May 03, 2016, 05:44:19 PM »
I've decided... Now how do I specify the same point, but at a Surface's elevation?
Is there not a transparent command to specify a point at Surface elevation?
« Reply #4 on: May 03, 2016, 05:57:42 PM »
'pn
BlackBox
« Reply #5 on: May 03, 2016, 06:14:32 PM »
« Reply #6 on: May 04, 2016, 08:32:52 AM »
let me test....
« Reply #7 on: May 04, 2016, 08:38:29 AM »
elect point object:
Select objects to raise or lower:
Resuming RAISELOWERFEATURESBYREF command.
Select objects to raise or lower: 1 found, 1 total
Specify point: Distance 132.55',  Grade 1.99,  Slope 50.33:1,  Elevation 1360.00'
Specify grade or [Slope/Difference] <1.99>:
after using 'po
it gets in a loop asking repeatedly to pick the point...
just hit enter
then the remaining prompts will follow
MSTG007
« Reply #8 on: May 04, 2016, 08:46:35 AM »
Yup.
Civil3D 2020
« Reply #9 on: May 04, 2016, 10:32:18 AM »
he must now be happily editing by reference.....or not
BlackBox
« Reply #10 on: May 04, 2016, 11:06:19 AM »
Apologies for the delayed response - I was unable to get this to work first thing this morning, only to get roped into putting out some fires, before I could even get back to the project I need to submit this afternoon (let alone this thread).
I appreciate the help, and will post back with some screenshot(s), command line output, etc at my soonest convenience.
Cheers
BlackBox
« Reply #11 on: May 05, 2016, 03:28:35 PM »
Okay - I wrapped up a few project submittals, and I'm still having trouble with this.
Neither 'PN, nor 'PO work - the command completes without error, but the Feature Line is never elevated - the only thing that is working is 'POS.
I've recorded a short Jing video clip to try and help clarify; I'm hoping that you see where I am going wrong.
If I specify the Difference command option, why is the difference (which is already acknowledged in the command line output!) not being applied automagically, instead of prompting me to manually enter same - only to have that manual input doubled? :-o
« Reply #12 on: May 05, 2016, 05:12:52 PM »
are you certain it is a COGO point you are attempting to reference?
SET a NEW ONE just to be sure...
