If you like cdddddddddddddddddddr:
; (setq aList '("01 "02" "03" "04" "05" "06" "07" "08" "09" "10" "11" "12" "13" "14" "15"))
; (ALE_List_NthCdr 8 aList) => ("09" "10" "11" "12" "13" "14" "15")
; (ALE_List_Member "11" aList) => ("11" "12" "13" "14" "15")
; (ALE_List_LastN 3 aList) => ("13" "14" "15")
; (ALE_List_FirstN 3 aList) => ("01" "02" "03")
; (ALE_List_LastN 10 aList) => ("06" "07" "08" "09" "10" "11" "12" "13" "14" "15")
; (ALE_List_FirstN 10 aList) => ("01" "02" "03" "04" "05" "06" "07" "08" "09" "10")
; (Ale_List_Slice 2 10 aList) => ("03" "04" "05" "06" "07" "08" "09" "10" "11")
; 2014/02/19 - n (Position) Nth like
(defun ALE_List_NthCdr (n l)
(repeat (/ n 1000) (setq l (Cd1000r l)))
(repeat (/ (setq n (rem n 1000)) 100) (setq l (Cd100r l)))
(repeat (/ (setq n (rem n 100)) 10) (setq l (Cd10r l)))
(repeat (/ (setq n (rem n 10)) 4) (setq l (cddddr l)))
(repeat (rem n 4) (setq l (cdr l)))
l
; 2014/03/01 for VERY long lists
(defun ALE_List_NthCdrL (n l)
(repeat (/ n 10000) (setq l (Cd10000r l)))
(repeat (/ (setq n (rem n 10000)) 1000) (setq l (Cd1000r l)))
l
; faster of member on long lists or short (1000 elements) if Item is near final position
(defun ALE_List_Member (i l)
(ALE_List_NthCdr (vl-position i l) l)
(defun ALE_List_LastN (n l)
(ALE_List_NthCdr (- (length l) n) l)
(defun First10 (l)
(list
(car l) (cadr l) (caddr l) (cadddr l) (cadddr (cdr l)) (cadddr (cddr l))
(cadddr (cdddr l)) (cadddr (cddddr l)) (cadddr (cddddr (cdr l)))
(cadddr (cddddr (cddr l)))
(defun First09 (n l)
( (eq 1 n) (list (car l)) )
( (eq 2 n) (list (car l) (cadr l)) )
( (eq 3 n) (list (car l) (cadr l) (caddr l)) )
( (eq 4 n) (list (car l) (cadr l) (caddr l) (cadddr l)) )
( (eq 5 n) (list (car l) (cadr l) (caddr l) (cadddr l) (cadddr (cdr l))) )
( (eq 6 n)
(list (car l) (cadr l) (caddr l) (cadddr l) (cadddr (cdr l)) (cadddr (cddr l)))
( (eq 7 n)
(list
(cadddr (cddr l)) (cadddr (cdddr l))
( (eq 8 n)
(list
(cadddr (cddr l)) (cadddr (cdddr l)) (cadddr (cddddr l))
( (eq 9 n)
(list
(defun Cdr09 (n l)
( (eq 1 n) (cdr l) )
( (eq 2 n) (cddr l) )
( (eq 3 n) (cdddr l) )
( (eq 4 n) (cddddr l) )
( (eq 5 n) (cddddr(cdr l)) )
( (eq 6 n) (cddddr(cddr l)) )
( (eq 7 n) (cddddr(cdddr l)) )
( (eq 8 n) (cddddr(cddddr l)) )
( (eq 9 n) (cddddr(cddddr(cdr l))) )
(defun ALE_List_FirstN (n l)
(reverse (ALE_List_NthCdr (- (length l) n) (reverse l)))
(defun ALE_List_Slice (n1 n2 l)
(reverse (ALE_List_NthCdr (- (length l) n2 1) (reverse (ALE_List_NthCdr n1 l))))
(defun Cd10r (l)
(cddddr(cddddr(cddr l)))
(defun Cd100r (l)
(cddddr(cddddr(cddddr(cddddr(cddddr(cddddr(cddddr
(cddddr(cddddr(cddddr(cddddr l)))))))))))))))))))))))))
(defun Cd10000r (l)
(Cd1000r(Cd1000r(Cd1000r(Cd1000r(Cd1000r(Cd1000r
(Cd1000r(Cd1000r(Cd1000r(Cd1000r l))))))))))
(defun Cd100000r (l)
(Cd10000r(Cd10000r(Cd10000r(Cd10000r(Cd10000r(Cd10000r
(Cd10000r(Cd10000r(Cd10000r(Cd10000r l))))))))))
(defun Cd1000r (l)
(cddddr(cddddr(cddddr(cddddr(cddddr l))))))))))))
(defun Cd10000r (l)
