Author Topic: Command redefined and INPUTSEARCHDELAY variable  (Read 4502 times)
Lupo76
« on: October 04, 2015, 05:01:16 AM »
Hello to all,
I redefined some AutoCAD commands such as. the MOVE (SPOSTA in Italian).
In a normal situation (without third-party applications), pressing "S" followed by Enter, start the SPOSTA command (MOVE in English).
This happens even though the user before pressing Enter waits several seconds.
In my case, having redefined a few commands, it seems that the auto-complete feature gives priority to native AutoCAD commands and not those redefined.
For example, when the user types in the command bar "S" and wait too long before pressing ENTER, it starts the command "SALVAVEL" (QSAVE in English), instead of the command SPOSTA(MOVE in English).
This happens even if the PGP file is set up correctly.
This is very annoying !!  :-(
I found the following solutions, but none of those I like:
1. Set to code the variable INPUTSEARCHDELAY = 600: greatly improves the situation but does not fully resolve, also the code (setvar "INPUTSEARCHDELAY" 600) is not compatible with BricsCAD or with older versions of AutoCAD.
2. Disable from code the autocompletion, however this is not nice to the end user.  :cry:
Do you have any other ideas?
« Last Edit: December 13, 2016, 11:54:29 PM by Lupo76 »
Lupo76
Re: Command redefined and INPUTSEARCHDELAY variable
« Reply #1 on: December 13, 2016, 11:56:00 PM »
No suggestions here?
There is a variable to change the native AutoCAD commands priority than the LISP or redefined commands with lisp?
Lupo76
« Reply #2 on: December 14, 2016, 03:27:15 AM »
To simplify the explanation of the problem and allowing you to reproduce it attached a lisp files created for this purpose and a video.
I look forward  :roll:
Randall Culp
« Reply #3 on: December 14, 2016, 08:57:29 AM »
What does function (c:redcommand) do??  It does not appear defined in the posted lisp function.
Randy Culp
(AKA CADaver)
roy_043
  • BricsCAD 18
« Reply #4 on: December 14, 2016, 09:28:11 AM »
Probably should be (c:RedefineCommand).
@Lupo76:
This problem seems like another good reason *not* to redefine commands...
Lupo76
« Reply #5 on: December 14, 2016, 10:38:34 AM »
Exact! I am attaching the correct lisp files
@Lupo76:
mmmmm....I can not change the behavior of my application, it would be too complex.
The redefined commands work properly for years.
So I would like to find a solution to this problem.
In other words it would be enough to find a way to force the AutoCAD command bar to also consider the LISP functions as well as the native commands.
BricsCAD already has this behavior! :-)
« Last Edit: December 15, 2016, 04:01:28 AM by Lupo76 »
Randall Culp
« Reply #6 on: December 14, 2016, 05:03:09 PM »
I must be missing something because I really don't see any benefit in the posted function other than it forces select objects prior to moving and prohibits grip moving.  The same can be accomplished by setting PICKFIRST to 0.
If you want native function and some new function, simply name the list function something else.
Im confused  :crazy2:
Randy Culp
(AKA CADaver)
Lupo76
« Reply #7 on: December 15, 2016, 01:48:15 AM »
The lisp that I put in here is just an example to describe the problem.
The full lisp are at least 200 lines of code ;-)
roy_043
  • BricsCAD 18
« Reply #8 on: December 15, 2016, 03:33:57 AM »
Does AutoCAD include the aliases in the .pgp file in the 'autocomplete list'?
Lupo76
« Reply #9 on: December 15, 2016, 04:00:47 AM »
PGP file is correct, but I have not found any settings to include or exclude aliases in the 'autocomplete list'.
This setting exists? where?
PS. I think that if you try the lisp that I attached, you have the same problem.... or not?  :-o
roy_043
  • BricsCAD 18
« Reply #10 on: December 15, 2016, 06:16:24 AM »
I use BricsCAD so I do not experience this problem. :-D
BricsCAD's autocomplete includes command aliases, hence my suggestion.
Lupo76
« Reply #11 on: December 15, 2016, 08:25:56 AM »
I too use BricsCAD, but my application MUST be also compatible with AutoCAD.
No idea on how to solve?  :cry:  :cry:
ChrisCarlson
« Reply #12 on: December 15, 2016, 08:33:09 AM »
Why are you using a lisp routine to accomplish this? "ALIASEDIT" should more than accomplish what you are looking to do
roy_043
  • BricsCAD 18
« Reply #13 on: December 15, 2016, 09:34:23 AM »
@Master_Shake: I think you have misunderstood the OP's problem.
ChrisCarlson
« Reply #14 on: December 15, 2016, 09:57:19 AM »
Call me confused then
  1.   (defun c:sposta ()
  2.     (movenew)
  3.   )
  4. (defun movenew ()
  5.   (princ "\n############ Move_RedefinedCommand ############## !!!!!!!!!")
  6.   (setq obj (ssget))
  7.   (command "_.move" obj "" pause pause)
  8. )
  9.
