Hello to all,
I redefined some AutoCAD commands such as. the MOVE (SPOSTA in Italian).
In a normal situation (without third-party applications), pressing "S" followed by Enter, start the SPOSTA command (MOVE in English).
This happens even though the user before pressing Enter waits several seconds.
In my case, having redefined a few commands, it seems that the auto-complete feature gives priority to native AutoCAD commands and not those redefined.
For example, when the user types in the command bar "S" and wait too long before pressing ENTER, it starts the command "SALVAVEL" (QSAVE in English), instead of the command SPOSTA(MOVE in English).
This happens even if the PGP file is set up correctly.
This is very annoying !!
I found the following solutions, but none of those I like:
1. Set to code the variable INPUTSEARCHDELAY = 600: greatly improves the situation but does not fully resolve, also the code (setvar "INPUTSEARCHDELAY" 600) is not compatible with BricsCAD or with older versions of AutoCAD.
2. Disable from code the autocompletion, however this is not nice to the end user.
Do you have any other ideas?
