So I'm trying to update some code that I use to check images within a drawing, and since I've upgraded my Acad to '09, I thought I would use the native managed calls. I can't seem to figure out how to get to the actual image that is inserted within the drawing from the RasterImageDef. When I was trying this a couple of years ago Tony told me about ' GetPersistentReactorIds ', but I wasn't able to use this method back then, but now I can. So I call that, and what gets returned is an ObjectIdCollection, and within that is object id's for the main image dictionary, and id's for an object that I don't seem to have a reference to, as it is calling it an ' ImpDBObject '. I have searched the net, and the help, and haven't been able to figure out what I'm supposed to use it as. I assume it is a reactor object, as with lisp I can follow it that way, but with .Net I can't. Maybe if I reference the correct .dll file, but I'm not sure which one.
Any help is appreciated. Thanks. If code is needed, let me know, and I'll try any clean it up enough to post.
