Author Topic: Send pdf to plotter/printer with lisp  (Read 3176 times)
HelpLispinSeattle
« on: April 27, 2010, 11:38:36 AM »
Hello,
I would like to make/create a pdf of a dwg then send/print the pdf silently to a plotter.
Can it be done with autolisp/visual lisp?
I've been researching command lines for acrobat but as I understand it they don't
support command lines for acrobat 8 & higher.
I dont need help with making/creating the pdf with lisp. Its what to do after it.
Any ideas?
David Bethel
Re: Send pdf to plotter/printer with lisp
« Reply #1 on: April 27, 2010, 12:52:43 PM »
OOPS,
I misread this one
What I do is:
  • plot to a postscript file in acad via autolisp
  • write a ps based on runfilex.ps
  • then open that file with Distiller
  • then send this to a plotter via a dos type binary copy
But it is not single step silent scenario.  I can do that with HPGL2 files, not PDFs
That allows me to sort the pages as required, and make a single multipage PDF.  -Daivd
R12 Dos - A2K
VovKa
  • Ukraine
« Reply #2 on: April 27, 2010, 05:08:03 PM »
you can try something other than acrobat
as for me, i use http://www.foxitsoftware.com/pdf/reader/reader3.php it's free and supports command line parameters
« Reply #3 on: April 27, 2010, 10:52:13 PM »
ghostscript
HelpLispinSeattle
« Reply #4 on: April 28, 2010, 09:56:46 AM »
Thank you guys for all your ideas. I think I found myself
a solution. I am going to use Dave Fulger's DosLib.
I will use one of the "Process Functions"....dos_shellexe.
Thank you again everyone!
Marc'Antonio Alessi
  • Marco
« Reply #5 on: December 21, 2016, 12:49:11 PM »
I found this old post... question: is there anyone who uses dos_shellexe to send PDFs to the printer?
Marc'Antonio Alessi
  • Marco
« Reply #6 on: December 22, 2016, 02:57:01 AM »
I try with a second question: in Windows I can send PDF files directly to default printer (less then 16 without modify Win registry), how can I send PDF to printer like in Windows Explorer?
roy_043
  • BricsCAD 18
« Reply #7 on: December 22, 2016, 04:34:51 AM »
Studying this VBscript solution may be helpful:
http://www.robvanderwoude.com/sourcecode.php?src=printpdf_vbs
Marc'Antonio Alessi
  • Marco
« Reply #8 on: December 22, 2016, 10:48:58 AM »
thanks for answering, after many tests I found a fairly simple solution with Acrobat Reader installed:
(setq PdfFil "Z:/Temp/Test1.pdf")
(DOS_SHELLEXE "AcroRd32.exe" (strcat "/t /h \"" PdfFil "\"") 0 3)
Marc'Antonio Alessi
  • Marco
« Reply #9 on: January 03, 2017, 11:17:42 AM »
To print many PDF copies I use:
; FlsLst = List of file names
(repeat NumCopies
  (foreach ForElm FlsLst
    (setq FilNam (strcat PatNam ForElm))
    (DOS_SHELLEXE "AcroRd32.exe" (strcat "/h /s /p \"" FilNam "\"") 0 3)
    (while (DOS_OPENP FilNam) (vl-cmdf "_.DELAY" 1))
Sometimes I need to delete the files after printing but with this method the cancellation can take place before printing is complete, is there a way to execute cancellation after printing? (Dos_OpenP + delay do not works)...
  (while (DOS_OPENP (strcat PatNam ForElm)) (vl-cmdf "_.DELAY" 1))
  (DOS_DELETE (strcat PatNam ForElm))
Other attempt:
(setq DelFlg (DOS_MSGBOXEX "Delete the files after plot?"       "Send PDF to Printer" '("No" "Yes") 4))
(DOS_GETPROGRESS "Printing" "Please wait..."      100)
  (setq FilNam (strcat PatNam ForElm)  Countr 1)
  (DOS_GETPROGRESS -1)
  (repeat NumCop
    (vl-cmdf "_.DELAY" 500)
    (while (DOS_OPENP FilNam) (vl-cmdf "_.DELAY" 500))
    (if (and (= NumCop Countr) (= 1 DelFlg))
      (progn (DOS_DELETE FilNam) (alert (strcat FilNam "\n" (itoa Countr))))
      (setq Countr (1+ Countr))
(DOS_GETPROGRESS T)
« Reply #10 on: January 03, 2017, 01:08:59 PM »
Based on these references:
http://www.robvanderwoude.com/commandlineswitches.php#Acrobat
http://two.pairlist.net/pipermail/reportlab-users/2003-January/001158.html
Have you tried something like this?:
    (repeat NumCop
        (DOS_SHELLEXE "AcroRd32.exe" (strcat "/N /T \"" FilNam "\" YourPrinterName") 0 3)
    (if (= 1 DelFlg) (DOS_DELETE FilNam))
(DOS_GETPROGRESS T)
Marc'Antonio Alessi
  • Marco
« Reply #11 on: January 04, 2017, 02:46:19 AM »
/n - Launch a new instance of Reader even if one is already open
/s - Don't show the splash screen
/o - Don't show the open file dialog
/h - Open as a minimized window
/p <filename> - Open and go straight to the print dialog
/t <filename> <printername> <drivername> <portname> - Print the file the specified printer
/N /T > now works better. Generous as always, thanks for your time.  :-)
« Reply #12 on: January 04, 2017, 08:05:19 AM »
Excellent, you're welcome - note that I also removed your counter variable  :wink:
alanjt
  • Standby for witty remark...
« Reply #13 on: January 04, 2017, 10:02:44 AM »
    (repeat NumCop
(DOS_GETPROGRESS T)
Cool
Dropbox
