Author Topic: Loading a block in the drawing without inserting it  (Read 6647 times)
iliekater
« on: January 18, 2008, 07:34:55 AM »
I know it may sound stupid but I need this in order to load an arrow block which to set it as symbols for dimensions . If that's not possible , is any other way to do this ?
jbuzbee
Re: Loading a block in the drawing without inserting it
« Reply #1 on: January 18, 2008, 08:18:17 AM »
If the block exists in another drawing, say a 'standards' drawing, you can use ObjectDBX to import it.  You could also create it from scratch via code in the drawing.  Which would you like to do?
James Buzbee
Windows 8
« Reply #2 on: January 18, 2008, 09:00:37 AM »
You can emake a BLOCK, which is then ready to be an INSERT.
;;  Example of a Entmake of a Block
(defun makearrow (blockname)
  ;;       Start of Block definition
  (entmake
    (list '(0 . "BLOCK") '(100 . "AcDbEntity") '(100 . "AcDbBlockBegin")
          (cons 2 blockname)  '(8 . "0")
          '(70 . 0)                  0= No Attributes, 2= Attributes
          '(10 0.0 0.0 0.0)
  ;;            Block objects
  (entmake '((0 . "SOLID") (8 . "0") (10 66.0 -1.42109e-014 0.0) (11 52.8688 -2.32308 0.0)
             (12 52.8688 2.32308 0.0) (13 52.8688 2.32308 0.0) (39 . 0.0)))
  (entmake '((0 . "LINE") (8 . "0") (10 0.0 0.0 0.0) (11 66.0 -1.42109e-014 0.0)))
  (entmake '((0 . "LINE") (8 . "0") (10 29.1563 -16.9136 0.0) (11 33.0 -7.10543e-015 0.0)))
  (entmake '((0 . "LINE") (8 . "0") (10 23.8848 16.2547 0.0) (11 29.1563 -16.9136 0.0)))
  (entmake '((0 . "LINE") (8 . "0") (10 16.6366 -8.7863 0.0) (11 23.8848 16.2547 0.0)))
  (entmake '((0 . "LINE") (8 . "0") (10 12.1311 8.7863 0.0) (11 16.6366 -8.7863 0.0)))
  ;;     This is the end of block marker
  (entmake (list '(0 . "ENDBLK") '(100 . "AcDbBlockEnd") '(8 . "0")))
SomeCallMeDave
« Reply #3 on: January 18, 2008, 09:15:26 AM »
What about something like
(setq fileName (findfile "YourBlockNameHere"))
(command "insert" FileName break)
iliekater
« Reply #4 on: January 18, 2008, 09:19:24 AM »
jbuzbee :
You can use ObjectDBX to import it.
What's ObjectDBX ? I couldn't find it in the Help files . Let me Specify here that I am using AutoCAD 2004 .
jbuzbee :
No , the symbol sometimes is very complicated . For example one of the symbols is a skull ! Therefor I can't redraw it with code .
CAB : I didn't understand the code . I think you use the entmake to create an entinity of block that will contain some lines . Unfortunatelly I couldn't run it .  :cry:
iliekater
« Reply #5 on: January 18, 2008, 09:24:34 AM »
SomeCallMeDave :
Wow , it really worked ! Thanks !
But how exactly does the "break" key work ?
« Reply #6 on: January 18, 2008, 09:39:37 AM »
You can entmake the block needed. All I posted was an example of making a block without inserting it.
It wasn't the block you want because you did not share that with us.
This was just an alternate solution.
jbuzbee
« Reply #7 on: January 18, 2008, 09:43:02 AM »
ObjectDBX is an undocumented ActiveX library that let's you "open" a drawing with out actuially opening it in the editor and extract data into another drawing.  I use it to import all our standards: blocks, layers, dimstyles, textstyles, annotation tags, etc.  It's very, very handy.
James Buzbee
Windows 8
daron
« Reply #8 on: January 18, 2008, 10:49:10 AM »
Wouldn't it be just as easy to use the design center to update or insert a block without actually inserting it? That functionality exists through DC.
iliekater
« Reply #9 on: January 18, 2008, 01:24:14 PM »
Daron :
It would be easy but code is much faster !
jbuzbee :
Sounds very interesting . Maybe it's a silly question , but where do I find it ? I can load as an ARX ?
CAB :
Well it smells like powder here , yet I'll add a frase from my initial post :
daron
« Reply #10 on: January 18, 2008, 01:44:44 PM »
What I used to do when I wanted a drawing in the DB, but not the drawing space itself is insert it to the center of the screen and erase it, through code of course.
jbuzbee
« Reply #11 on: January 18, 2008, 01:48:15 PM »
This is my Import Block routine - The majority of the code was originally penned by Tony Tanzillo. (thanks Tony!)
;;; ObjectDBX functions
;This will load the ObjectDBX activex module
(if (< (atoi (getvar "AcadVer")) 16)
  (cond ((vl-registry-read "HKEY_CLASSES_ROOT\\ObjectDBX.AxDbDocument\\CLSID"))
        ((not (setq dbxserver (findfile "AxDb15.dll")))
         (alert "Error: Can't locate ObjectDBX Library (AxDb15.dll)"))
        (t
         (startapp "regsvr32.exe" (strcat "/s \"" dbxserver "\""))
         (or (vl-registry-read "HKEY_CLASSES_ROOT\\ObjectDBX.AxDbDocument\\CLSID")
             (alert "Error: Failed to register ObjectDBX ActiveX services.")))))
;;;(setq dwgname(findfile "AecLayerStd.dwg"))
;;; Open a dbxDoc ;
;;; use (setq dbxDocument(jb:OpenDbxDocument dwgname)) ;
(defun jb:OpenDbxDocument  (DwgName / app doc dbxopen dbxDoc)
  (setq app (vlax-get-acad-object)
        doc (vla-get-ActiveDocument app))
  (if (/= dwgname (vla-get-fullname doc))
    (progn (cond ((= (substr (getvar "ACADVER") 1 5) "15.06")
                  (setq dbxDoc  (vla-GetInterfaceObject app "ObjectDBX.AxDbDocument")
                        dbxopen (vl-catch-all-apply 'vla-open (list dbxDoc DwgName))))
                 (t
                                  app
                                  (strcat "ObjectDBX.AxDbDocument." (substr (getvar "acadver") 1 2)))
                        dbxopen (vl-catch-all-apply 'vla-open (list dbxDoc DwgName)))))
           (if (vl-catch-all-error-p dbxopen)
             (setq dbxDoc nil))))
  dbxDoc)
;;; (vlax-dump-Object dbxDoc t)
;;; Close dbxDoc
;;; (jb:CloseDbxDocument dbxDocument)
(defun jb:CloseDbxDocument  (dbxdoc)
  (if (= (type dbxDoc) 'VLA-OBJECT)
    (progn (vlax-release-object dbxDoc) (setq dbxDoc nil))))
;;; Import a Block from a DBX Document ;
;;; Arguments: dwg; a valid drawing name and path ;
;;;   block; name of the block to import ;
;;; Return: the block object ;
(defun jb:ImportBlock  (dwg block / dbxDoc bb dbb newblk)
  (if dwg
    (setq dbxDoc (jb:OpenDbxDocument dwg)))
  (if dbxDoc
    (progn (setq bb  (vla-get-blocks dbxDoc)
                 dbb (vla-get-blocks (vla-get-ActiveDocument (vlax-get-acad-object))))
           (if (not
                 (vl-catch-all-error-p (vl-catch-all-apply 'vla-item (list bb block))))
             (setq newblk (vl-catch-all-apply
                            'vla-CopyObjects
                            (list dbxDoc
                                  (vlax-safearray-fill
                                    (vlax-make-safearray vlax-vbObject '(0 . 0))
                                    (list (vla-item bb block)))
                                  dbb))))))
  (if dbxdoc
    (jb:closedbxdocument dbxDoc))
  newblk)
;;; Import Multiple Blocks from a DBX Document ;
;;;   listofblocks; list of names to import;
(defun jb:ImportBlocks  (dwg listofblocks / dbxDoc ii bb dbb newblk blockstoImport)
  (if dwg
  (if dbxDoc
      (foreach i listofblocks
           (if (not
                 (vl-catch-all-error-p (vl-catch-all-apply 'vla-item (list bb i))))
    (setq blockstoImport(append blockstoImport(list i)))))
      (if blockstoImport
(foreach ii blockstoImport
                            'vla-CopyObjects
                            (list dbxDoc
                                    (list (vla-item bb ii)))
                                  dbb)))))))
  (if dbxdoc
  (vlax-release-object dbb)
  newblk)
;;; Return Block list from a DBX Document ;
;;; Return: List of strings ;
(defun jb:ReturnDBXBlocks  (dwg / dbxDoc ret)
  (if dwg
  (if dbxDoc
    (progn (vlax-for x(vla-get-blocks dbxDoc)
           (if (and(= (vlax-get x 'isxref) 0)
                   (not(vl-string-search(chr 42)(vla-get-name x)))
                      (not(vl-string-search(chr 124)(vla-get-name x))))
             (setq ret (append ret(list (vla-get-name x))))))))
  (if dbxdoc
  ret)
Notice that this accesses the dbxDocuments "Block" collection.  These functions can be easily modified to access any collection: Layers, Views, etc.  Also remember that ModelSpace and PaperSpace(s) are Blocks.  So you can access graphical data as well.
« Last Edit: January 18, 2008, 02:21:17 PM by jbuzbee »
James Buzbee
Windows 8
« Reply #12 on: January 18, 2008, 02:19:32 PM »
This is my Import Block routine - The majority of the code was originally penned my Tony Tanzillo. (thanks Tony!)
<snip>
A little TMI JB.   :wink:
jbuzbee
« Reply #13 on: January 18, 2008, 02:22:17 PM »
oops.  I've been seizing allot today.  time to get off the computer . . ..
James Buzbee
Windows 8
« Reply #14 on: January 18, 2008, 02:38:30 PM »
I hope everything is alright, and it is always a good thing to get off the computer every now and then.
