Could you provide some documentation of the intent of
(xdrx-begin) and (xdrx-end) ??
more generally, can you give an indication when the documentation will be translated ?
side note,
I noticed you use a go board in your splash-screen.
I assume you play ??
Thanks for the suggestion
There is a function manual in the installation package. I will post here to introduce the usage from typical applications and functions. The best way is to look at the code.
xdrx-begin does some initial settings, xdrx-end does some aftermath, such as restoring system variables, releasing dynamic objects, UNDO END, etc.
The operation between xdrx-begin and xdrx-end can be UNDO once
I only know a little bit about Go. I prefer the thinking of Go, which affects some codes.
