I have a drawing with a .sid file in it and I need to convert it to pdf. The last time I had done this was in 2006 (AFAIK) and I believe I used Acrobat Distiller, which I no longer have.
When I use my current pdf 'printer', I get some weird results. Only a portion of the drawing linework comes through. The border doesn't get converted and neither does the .sid image. I'm using the Adobe PDF Converter, which is newer by a few years and so far, I can't find an option that would fix this problem.
Anyone have any ideas?
