Author Topic: Working in metric (sort of)  (Read 12252 times)
Matt__W
  • I like my water diluted.
« on: January 26, 2009, 04:58:54 PM »
Can someone enlighten me on this... I need to create some schematic site plans that need to be in metric units.  I've got a site plan (scanned TIF file) that is supposedly scaled at 1:50 meters.  I've got a building footprint that is in architectural units.  I think I've managed to bring in the building footprint at a metric scale.  The big question I have is, how do I create a metric scaled viewport?  I know the ZOOM 1/96XP (for example) trick, but how does that translate into metric?
Autodesk Expert Elite
Re: Working in metric (sort of)
« Reply #1 on: January 26, 2009, 05:02:51 PM »
metric is more like
1:10
1:500
1:1000
« Reply #2 on: January 26, 2009, 05:07:17 PM »
Spike Wilbury
« Reply #3 on: January 26, 2009, 05:16:06 PM »
Have been a loooooooooooooooooooong time that I stop doing drafting in metric (metros).... maybe this might help you:
zoomxp [1:500 ]'.zoom 2xp
zoomxp [1:750 ]'.zoom 1.33333xp
zoomxp [1:1000 ]'.zoom 1xp
zoomxp [1:2000 ]'.zoom 0.5xp
zoomxp [1:2500 ]'.zoom 0.4xp
zoomxp [1:5000 ]'.zoom 0.2xp
zoomxp [1:10000]'.zoom 0.1xp
zoomxp [1:20000]'.zoom 0.05xp
zoomxp [<-1:50000]'.zoom 0.02xp
zoomxp [ 1:250]'.zoom 4xp
zoomxp [ 1:200]'.zoom 5xp
zoomxp [ 1:125]'.zoom 8xp
zoomxp [ 1:100]'.zoom 10xp
zoomxp [ 1:75]'.zoom 13.33333xp
zoomxp [ 1:50]'.zoom 20xp
zoomxp [ 1:25]'.zoom 40xp
zoomxp [ 1:20]'.zoom 50xp
zoomxp [ 1:12.5]'.zoom 80xp
zoomxp [ 1:10]'.zoom 100xp
zoomxp [ 1:5 ]'.zoom 200xp
zoomxp [ 1:2 ]'.zoom 500xp
zoomxp [ 1:1 ]'.zoom 1000xp
zoomxp [ 2:1 ]'.zoom 2000xp
zoomxp [<-5:1 ]'.zoom 5000xp
« Reply #4 on: January 26, 2009, 05:16:43 PM »
Strucmad
« Reply #5 on: January 26, 2009, 05:33:57 PM »
Matt,
Those scale factors from LE are right
They appear to be to be scaling drawn millimetres to metres as well.  e.g. [1:1000]'.zoom 1xp  this is really 1/(1000/1000)......converting it to metres
so if your units are in metres then 1:1000 -> in metres,  is zoom 1/1000xp or zoom 0.001xp
1:100 - zoom 1/100xp , or .01xp
1:200 - zoom 1/200xp , or .005xp
1:500 - zoom 1/500xp, or .002xp
give this a whirl...I dont use vports much myself so fingers crossed  :-D
Strucmad
« Reply #6 on: January 26, 2009, 05:35:56 PM »
MJ whoever put Centimetres in that table should be shot....There is no such thing, and they should never be spoken about.. :lol: :wink: :lmao:
« Reply #7 on: January 26, 2009, 05:43:19 PM »
that would be courtesy of our friends at autodesk
Alan Cullen
« Reply #8 on: January 26, 2009, 06:46:40 PM »
Have to agree Paul...it's either millimetres or metres....I have never seen cms used....and I hate getting drawings from architects in mm too. Cause we have to rescale/move/rotate their work to get their stuff back onto the survey grid. Then every time they send us a revision (every day) we have to repeat the exercise. Aarrrggghhhh.
jnieman
« Reply #9 on: January 26, 2009, 07:03:19 PM »
It's because 'cm' is apparently used as the standard unit for scientific crap, I think.
It seems that every PRACTICAL application of the units is 'mm' as the base (or meters on things of that scale) ... when I did precision machining and our clients sent us metric drawings, we always read in mm... our tools were mm... no cm anywhere as the units.  I've not done architectural or engineering with metric, but apparently you guys seem to say it's mm too.
So other than measuring a person's height, what IS cm used for? lol...
In the USA, we're taught that 'cm' is the "base unit" for metric linear notation, and not meter for some reason.
« Reply #10 on: January 26, 2009, 07:07:30 PM »
you guys be sure to let autodesk in on this will ya?    :lmao:
Strucmad
« Reply #11 on: January 26, 2009, 07:32:54 PM »
The whole metric S.I. unit thing is a 10^3 concept..
e.g.
millimetre 10^-3 metres
metre 10^0 metres
kilometre 10^3 metres
Base unit is metre
works for every type of measurement
grams, kilograms, litres, kilolitres, megalitres
even computers are metric lol.
Kilobyte = 10^3 bytes
Megabyte = 10^6 bytes
Gigabyte = 10^9 bytes
Terrabyte = 10^12 bytes
so when you use centimetres its 10^-2 it screws the whole system up....
I think cm are primarily used in medicine, blood flow (cubic centimetres per second) or 5 ccs stat... :-D
bloody medical profession..gods unto themselves..
And Josh we still measure our heights in feet and inches ... go figure  :lol:
« Last Edit: January 26, 2009, 08:59:41 PM by PS_Port »
jnieman
« Reply #12 on: January 26, 2009, 07:41:09 PM »
YEA, someone told me you used feet and inches, but I was totally unaware... someone said it's only England that uses cm for height or somethign?  I may be way off.
Also, can you tell I'm American, totally oblivious to the rest of the known world? :P
thanks for the insight... it did seem to me that only scientific (like you said, medical) use cm... weird...
Alan Cullen
« Reply #13 on: January 26, 2009, 07:54:18 PM »
Yup...height in ft and ins....
Also (being the keen fisherman I am)...fish weight is still in pounds, water depth is still in feet, distance over the water is still in nautical miles, and plane heights are still in feet.
So our current generation know both imperial and metric, although the schools are trying to knock the imperial out of them. But while my generation is still alive, there will always be imperial.  :lmao: :lmao: :lmao:
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #14 on: January 26, 2009, 09:19:04 PM »
CM are also used for ladies sewing and for cake tin sizes .. :)  8" pie dish is 203 mm but called 20 CM
Called Kerry in my other life
I live at UTC + 13.00
