Code Red => AutoLISP (Vanilla / Visual) => Topic started by: Andrea on January 06, 2016, 02:20:23 PM
Hi everyone..
the drawing attached have 8MB....but no entity..
I'm trying to find out what is the cause..
anyone can take a look and tell me what's the problem ?
Thank you.
Drawing contains 3680 anonymous block definitions and 136575 entries in the ACAD_DGNLINESTYLECOMP dictionary.
Try the following:
Here's (http://www.theswamp.org/index.php?topic=9433.msg121330#msg121330) a tool as well.
That's exactly what I used to diagnose the drawing - a great utility from MP.
That's pretty sweet! Thanks for sharing. 8-)
Yup .. I've been using it for years :). It's amazing how littered drawings are nowadays.
We do quite a large amount of plat production here and the drawing with the least amount of objects will have the largest file size ever! It's all from doing a "save as" on a drawing that was done a year ago and just reusing it over and over and over... :rolleyes2:
Some of our production techs don't even know how to start with a TEMPLATE or how to create a NEW drawing. :grumpy:
Most of this has been corrected by now but once in a while we'll come across one of those "old balloon" drawings.
Saludos Amigos ..... months ago I got a problem with me a file with very little information but large ..... I was suffering for several days until I got the solution ...... Got Somewhere following hotfix and hallelujah .... problem solved .....
the file is reduced test4.dwg to 74k ......
Command: NETLOAD
Command: DGNPURGE
Purged 1463 unreferenced complex linetype records (of 1463).
Purged 136575 unreferenced strokes (of 136575).
Command:
Command:
Command: _qsave Updating Indexes for block *Model_Space
Done.
Done.
the address is https://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autocad-C2-AE-dgn-hotfix.html?v=2013
excuse the English .... bye
Thank you Guys..
Hi Lee,..
Question...how did you find that it was the "acad_dgnlinestylecomp" dict ?
Thank you Guys..
Hi Lee,..
http://www.theswamp.org/index.php?topic=50734.msg558684#msg558684
Thank you Guys..
Hi Lee,..
Sorry,..my poor English...
I mean,...without this great tool....where do you start for looking at ?
after purge and audit,..what must be the next step to look ?
the fact is that each problem have a solution...but I resolve most of them by a combinaison of "logic" and "deduction" and make test for each steps.
but when I can't found any more steps....how you guys doing to find out what the problem can be ?
search on the net,...ok,...but having the answer do not tell me why this issue is present and how can I found the right direction to look at..
it's like proxy's entities...who we never know wich kind of proxy's are..
maybe I'm not clear again...sorry for that..
thank you.
Doesn't the -exporttoautocad command get rid of all the proxies? Explodes them into simple Autocad entities, I thought.
Any time Autocad tells me there are proxies in a file I'm opening, I use that right away.
Thank you Guys..
Hi Lee,..
thank you.
Drawing size has to come from somewhere, and not everything is an entity (line, circle, etc.). A lot of size comes down to data objects, which can be attached to entities or the drawing itself. The latter is one of the first places I look, checking for various non-standard dictionaries (like AEC and AutoPLANT gunk).
Thank you Guys..
Hi Lee,..
Aside from an obvious abundance of graphical entities, I would simply look for collections (including dictionaries) which contain large numbers of objects - of course, MP's 'Counts' program performs this analysis automatically for you, making it very easy to identify such bloated collections.
Hi Andrea
You can try http://www.blog-cao.com/article/programmation/jav-autocad-purger-dessin-nettoyer-vide/ (http://www.blog-cao.com/article/programmation/jav-autocad-purger-dessin-nettoyer-vide/)
Et en plus, il est en français 8-)
Thank you all for your response...
I already have a cleaning tool who clean all...
Unfortunatly I've discovered a little issue with it...
who do not purge DGN linetype...what ever the option is checked or not..
So,..that's why I've asked questions...
I thought that the DGN was purged by running my tools..
ppfft...shame on me.. :wideeyed2:
Thanks again
