Author Topic: Help please, etransmit to all the files  (Read 1240 times)
Aldo
« on: April 05, 2017, 08:08:26 PM »
Dear friends, I ask for help to modify this routine, I asked for help from the author but I did not receive any response. I hope you have no problem helping me. What I really want is to add the ETRANSMIT routine to your routine in such a way that it generates a zip file for each file Dwg to clean, very grateful for the support, regards.
;;;CADALYST 03/05 Tip2023: PurgeFiles.lsp          Directory Clean Up          (c) Andrzej Gumula
;;; [c]2004 Andrzej Gumula, Katowice, Poland
;;; e-mail: a.gumula@wp.pl
;;; This routine purge dwg files from selected folder
(defun c:PurgeFiles (/ FilesList DwgPath SubDir Files File)
(defun GetFolder (/ Dir Item Path)
  ((setq Dir (vlax-invoke (vlax-get-or-create-object "Shell.Application") 'browseforfolder 0 "Select folder with DWG files:" 1 ""))
    ((not (vl-catch-all-error-p (vl-catch-all-apply 'vlax-invoke-method (list Dir 'Items))))
     (setq Item (vlax-invoke-method (vlax-invoke-method Dir 'Items) 'Item))
     (setq Path (vla-get-path Item))
     (if (not (member (substr Path (strlen Path) 1) (list "/" "\\")))
      (setq Path (strcat Path "\\"))
     );end if
   );end cond
 );end cond
 Path
);end GetFolder
(defun vl-findfile (Location / DirList Path AllPath)
 (MakeDirList Location)
 (setq DirList (cons Location DirList))
 (foreach Elem DirList
  (if (setq Path (vl-directory-files Elem "*.dwg"))
   (foreach Item Path (setq AllPath (cons (strcat Elem "/" Item)  AllPath)))
  );end if
 (reverse AllPath)
);end vl-findfile
(defun MakeDirList (Arg / TmpList)
 (setq TmpList (cddr (vl-directory-files Arg nil -1)))
  (TmpList
   (setq DirList (append DirList (mapcar '(lambda (z) (strcat Arg "/" z)) TmpList)))
   (foreach Item TmpList (MakeDirList (strcat Arg "/" Item)))
 );end cond
);end MakeDirList
(if (not FileSystemObject)
  (setq FileSystemObject (vla-getInterfaceObject (vlax-get-acad-object) "Scripting.FileSystemObject"))
);end if
((= (getvar "SDI") 0)
 ((setq DwgPath (GetFolder))
  (initget "Yes No")
  (setq Subdir (cond ((getkword "\nLooking for subfolders? No,[Yes]: "))
                                    (T "Yes")))
  (if (equal SubDir "Yes")
   (setq Files (vl-findfile (substr DwgPath 1 (1- (strlen DwgPath)))))
   (setq Files (mapcar '(lambda (x) (strcat dwgpath x))(vl-directory-files DwgPath "*.dwg" 1)))
  );end if
  (setq Files (mapcar 'strcase Files))
    (Files
     (vlax-for & (vla-get-documents (vlax-get-acad-object )) (setq FilesList (cons (strcase (vla-get-fullname &)) FilesList)))
     (foreach & Files
                ((not (member & FilesList ))
                  ((/= (logand (vlax-get-property (vlax-invoke-method FileSystemObject 'getfile &) 'Attributes) 1) 1)
                     ((setq File (vla-open (vla-get-documents (vlax-get-acad-object)) &))
                      (prompt (strcat "\nPurge " & ". Please wait..."))
              (vla-purgeall File)
                      (prompt (strcat "\nSave and close " &))
                      (vla-save File)
                      (vla-close File)
                      (vlax-release-object File)
                     (T (prompt (strcat "\nCannot open " & "\nDrawing file was created by an incompatible version. ")))
                   );end cond
                  (T (prompt (strcat & " is read-only. Purge canceled. ")))
                 );end cond
                (T (prompt (strcat & " is open now. Purge canceled. ")))
      );end cond
     );end foreach
    (T (prompt "\nNothing files found to purge. "))
  );end cond
 (T (prompt "\nNothing selected. "))
);end cond
(T (prompt "\nThe routine is not available in SDI mode. "))
);end cond
);end c:PurgeFile
(prompt "\nLoaded new command PurgeFiles. ")
(prompt "\n[c]2004 Andrzej Gumula. ")
