Author Topic: Xref block  (Read 3628 times)
Coder
Xref block
« on: December 19, 2013, 02:55:56 AM »
Hello guys .
Is there a way to not select Xref blocks with the ssget function ?
(setq bks (ssget '((0 . "INSERT")))) ;
Thanks in advance  :-)
kruuger
Re: Xref block
« Reply #1 on: December 19, 2013, 04:01:18 AM »
Hello guys .
Thanks in advance  :)
yes. you need to create BlockNameFilter function:
(ssget (list (cons 0 "INSERT") (cd:009_BlockNameFilter)))
(defun cd:009_BlockNameFilter ()
  (cons 2 (strcat "`*U*," (cd:STR_ReParse (cd:SYS_CollList "BLOCK" (+ 2 4) ",")))
it is a part of this program:
http://cad.pl/ftp/Tools/009_RedefineBlockProperties/RedefineBlockProperties.lsp
library functions are here (CadPack.lsp):
http://forum.cad.pl/cadpl-pack-v1-lsp-t78161.html
kruuger
Coder
Re: Xref block
« Reply #2 on: December 19, 2013, 07:57:18 AM »
Thank you kruuger for your help .
I lost with all these options that you posted  :embarrassed:
Can you please clarify ?
Re: Xref block
« Reply #3 on: December 19, 2013, 08:43:34 AM »
Try this:
(defun _foo (/ b fltr)
  (setq fltr "")
  (while (setq b (tblnext "block" (not b)))
    (and (assoc 1 b) (setq fltr (strcat "~" (cdr (assoc 2 b)) "," fltr)))
  (if (zerop (strlen fltr))
    fltr
(setq bks (ssget "_X" (list '(0 . "INSERT") (cons 2 (_foo)))))
« Last Edit: December 19, 2013, 09:26:19 AM by ronjonp »
ribarm
  • Marko Ribar, architect
Re: Xref block
« Reply #4 on: December 19, 2013, 09:08:13 AM »
Maybe this :
(defun c:ss~xref ( / ss adoc blks l )
  (setq adoc (vla-get-activedocument (vlax-get-acad-object)))
  (setq blks (vla-get-blocks adoc))
  (vlax-for item blks
    (if (eq (vla-get-isxref item) :vlax-true)
        (setq l (cons (list item (vl-catch-all-apply 'vla-get-xrefdatabase (list item))) l))
        (vla-unload item)
  (setq ss (ssget '((0 . "INSERT"))))
  (foreach item l
    (if (eq (type (cadr item)) 'vla-object)
      (vla-reload (car item))
  (sssetfirst nil ss)
M.R. on Youtube
kruuger
Re: Xref block
« Reply #5 on: December 19, 2013, 09:20:00 AM »
I lost with all these options that you posted  :oops:
if BL1, BL2, BL3 (xref), BL4, BL5 (xref) are dwg blocks
you need to go thru all all of them - omit xref's - and create string:
"BL1,BL2,BL4"and this one pass to ssget
(ssget (list (cons 0 "INSERT") (cons 2 "BL1,BL2,BL4")))k.
Coder
Re: Xref block
« Reply #6 on: December 20, 2013, 04:06:53 AM »
Hello guys .
ron your codes didn't work .  :-(
ribarm your codes unloaded one xref only to allow me to select blocks but the other xrefblocks didn't unloaded and they included with the selection .
kruuger , your guide is ok and I hope I can make it .
Many thanks
Re: Xref block
« Reply #7 on: December 20, 2013, 08:29:21 AM »
This seems to work:
  (setq fltr "")
    (and (assoc 1 b) (setq fltr (strcat (cdr (assoc 2 b)) "," fltr)))
    fltr
(setq bks (ssget "_X" (list '(0 . "INSERT") '(-4 . "<NOT") (cons 2 (_foo)) '(-4 . "NOT>"))))
« Last Edit: December 21, 2013, 08:28:39 AM by ronjonp »
ribarm
Re: Xref block
« Reply #8 on: December 20, 2013, 09:02:19 AM »
I didn't notice that CAD won't unload all attached Xrefs, only what I thought was the issue was how to reload them back as previous state was... Here is my slight improvement ab that... On my CAD it unloads all Xrefs... But if it doesn't try my second code from this post...
(defun c:ss~xref ( / ss adoc blks )
  (vla-startundomark adoc)
  (vlax-for item blks
      (vla-unload item)
  (command "_.undo" "")
  (sssetfirst nil ss)
(defun c:ss~xref ( / ss adoc )
  (command "_.-xref" "u" "*")
  (sssetfirst nil ss)
« Last Edit: December 20, 2013, 09:08:02 AM by ribarm »
M.R. on Youtube
Re: Xref block
« Reply #9 on: December 20, 2013, 07:03:02 PM »
I would follow a similar route to Ron, but would probably write it like this:
  1. (
  2.     (lambda ( / a b )
  3.         (while (setq a (tblnext "block" (null a)))
  4.             (if (= 4 (logand 4 (cdr (assoc 70 a))))
  5.                 (setq b (vl-list* "," (cdr (assoc 2 a)) b))
  6.             )
  7.         )
  8.         (ssget "_X"
  9.             (cons '(0 . "INSERT")
  10.                 (if b
  11.                     (list
  12.                        '(-4 . "<NOT")
  13.                         (cons 2 (apply 'strcat (cdr b)))
  14.                        '(-4 . "NOT>")
  15.                     )
  16.                 )
  17.             )
  18.         )
  19.     )
  20. )
Ron, note that your code will not select anything if there are no xrefs present in the drawing  :wink:
Coder
Re: Xref block
« Reply #10 on: December 21, 2013, 08:02:56 AM »
the last three posts work as i wanted , thank you all for your great help .  :-)
Re: Xref block
« Reply #11 on: December 21, 2013, 08:26:38 AM »
  1. (
  6.             )
  7.         )
  8.         (ssget "_X"
  10.                 (if b
  11.                     (list
  12.                        '(-4 . "<NOT")
  14.                        '(-4 . "NOT>")
  15.                     )
  16.                 )
  17.             )
  18.         )
  19.     )
  20. )
Ron, note that your code will not select anything if there are no xrefs present in the drawing  ;)
I see that now  :oops:   **Fixed  :D
..  I wonder why the ~name1,~name2 filter would not work?
« Last Edit: December 21, 2013, 08:44:15 AM by ronjonp »
Re: Xref block
« Reply #12 on: December 21, 2013, 11:50:08 AM »
The pattern argument for wcmatching (I believe the underpinning for ssget filtering) functions akin to an 'OR', not an 'AND'.
For example, if you had inserts by the names of "A", "B" and "C" (ssget "x" '((0 . "insert")(2 . "~A,~B,~C"))) would actually select them all (because "A" matches "~B" etc).
In order to achieve what you intended you would have to do something like:
  1. (ssget "x"
  2.    '(   (0 . "insert")
  3.         (-4 . "<and")
  4.         (2 . "~A")
  5.         (2 . "~B")
  6.         (2 . "~C")
  7.         (-4 . "and>")
  8.     )
  9. )
Thus, given a variable xref_names that's self describing:
(interactive)
  1.     (append
  2.        '((0 . "insert")(-4 . "<and"))
  3.         (mapcar (function (lambda (x) (cons 2 (strcat "~" x)))) xref_names)
  4.        '((-4 . "and>"))
  5.     )
  6. )
(non-interactive)
  1. (ssget "x"
  2.     (append
  3.        '((0 . "insert")(-4 . "<and"))
  4.         (mapcar (function (lambda (x) (cons 2 (strcat "~" x)))) xref_names)
  5.        '((-4 . "and>"))
  6.     )
  7. )
Of course, only applicable if xrefs are actually present in the drawing, in the interests of brevity <something I'm not usually known for> that (pre)determination not detailed here.
All that said, the (-4 . "<not") ... (-4 . "not>") alternative Lee detailed would be the route I'd suggest -- just thought I'd respond to your "wonder why ..." musing.
Cheers. :)
« Last Edit: December 21, 2013, 12:14:23 PM by MP »
