CAD Forums => Vertically Challenged => Land Lubber / Geographically Positioned => Topic started by: Mark on November 21, 2006, 12:18:05 PM
Can you move your points using the MOVE command? I thought I could do this in '06, it doesn't work in '07.
It works for me in '07 on an '06 drwang, but I haven't tried with points created in '07. Are your points locked or protected in prospector or by their layer?
Well I just tried this in a new '07 file and it worked. It doesn't work for me in a '06 file. :-)
*edit*
But there was no points in the '06 dwg when I started ......... confused
There may be something in your point group settings or layer affecting this as well.
There also seems to be some rather severe problems with grips in C3D if you have your running OSNAPS turned on. I've noticed them with labels. Could that possibly be part of it?
