Author Topic: Tool Palette Icon display problem  (Read 1011 times)
hudster
« on: January 30, 2008, 11:24:58 AM »
I have two blocks with the attributes in each one set as middle centre, and inserted in the centre of the block, the second block is the first one, saved and altered to create a new block.
But on the tool palette, one attribute is displayed as middle center, and one as being middle left, as per the image below.
Is there anything I can do to get the tool palette image to display correctly?
hudster
Re: Tool Palette Icon display problem
« Reply #1 on: January 30, 2008, 11:45:18 AM »
I solved it.
I inserted the block into a new drawing, blocked it out using the wblock option, and saved it over the original.
The icon now displays correctly.
