I have two blocks with the attributes in each one set as middle centre, and inserted in the centre of the block, the second block is the first one, saved and altered to create a new block.
But on the tool palette, one attribute is displayed as middle center, and one as being middle left, as per the image below.
Is there anything I can do to get the tool palette image to display correctly?
