Author Topic: [Topology-Hatch]Topological relationships of HATCH Boundaries(2) (LOOP)  (Read 950 times)
xdcad
The following code demonstrates the process of using the XDRX API to obtain the boundary LOOP topological relationship of the filled entity.
1. Pick up and HATCH
2. Pick a test point near a boundary
3. The boundary entity is displayed in magenta, and all LOOPs inside the boundary are displayed in yellow.
  1. (defun c:tt ()
  2.    (if (and (setq e (xdrx_entsel "\nPick a HATCH<exit>:" '((0 . "HATCH"))))
  3.             (xdrx_pickset_redraw e)
  4.             (setq p (getpoint "\nClick a little near the HATCH Ring <Exit>:"))
  5.        )
  6.      (progn
  7.        (xdrx_begin)
  8.        (setq mp (xdrx_hatch->mpolygon e)
  9.              mp (entlast)
  10.        )
  11.        (if (and (setq closestLoop
  12.                        (xdrx_getpropertyvalue mp "ClosestLoopTo" p)
  13.                 )
  14.                 (setq childLoops
  15.                        (xdrx_getpropertyvalue
  16.                          mp
  17.                          "childloops"
  18.                          closestloop
  19.                        )
  20.                 )
  21.            )
  22.          (progn
  23.            (setq loopdata (xdrx_getpropertyvalue mp "MPolygonLoopAt" closestloop))
  24.            (xdrx_polyline_make loopdata)
  25.            (xdrx_setpropertyvalue (entlast) "constantwidth" 20.0 "color" 6)
  26.            (setq i -1)
  27.            (mapcar '(lambda (x)
  28.                       (setq loopdata (xdrx_getpropertyvalue
  29.                                        mp
  30.                                        "MPolygonLoopAt"
  31.                                        x
  32.                                      )
  33.                       )
  34.                       (xdrx_polyline_make loopdata)
  35.                       (xdrx_setpropertyvalue
  36.                         (entlast)
  37.                         "constantwidth"
  38.                         20.0
  39.                         "color"
  40.                         2
  41.                       )
  42.                     )
  43.                    childloops
  44.            )
  45.          )
  46.        )
  47.        (xdrx_entity_delete mp)
  48.        (xdrx_pickset_redraw e t)
  49.        (xdrx_end)
  50.      )
  51.    )
  52.    (princ)
  53. )
The above LISP code uses the XDRX-API, which can be downloaded from https://github.com/xdcad/XDrx-API
The XDRX API encapsulates AcDb, AcEd, AcGe, AcBr... C++ library, using C++ methods to develop LISP programs.Thousands of Lisp functions are available.
https://sourceforge.net/projects/xdrx-api-zip/
http://bbs.xdcad.net
