Author Topic: Survey Figures - cannot find Basecurve method?  (Read 1585 times)
surveyor_randy
« on: May 30, 2014, 10:44:00 AM »
This is a Civil 3D question.
I'm trying to use the Basecurve method of the surveyfigure object and it isn't there.  I get a error message saying that "basecurve is not a member of Autodesk.AECC.Interop.Survey.AeccSurveyFigure"
Dim survFig As AeccSurveyFigure = TryCast(TR.GetObject(Res1.ObjectId, OpenMode.ForWrite), AeccSurveyFigure)
Dim baseCurve As Curve = survFig.Basecurve()
I'm referencing:
accoremgd
acdbmgd
acmgd
Autodesk.AEC.Interop.Base
Autodesk.AEC.Interop.UIBase
Autodesk.AECC.Interop.Roadway
Autodesk.AECC.Interop.UiRoadway
Autodesk.AECC.Interop.UiSurvey
What am I missing.  I'm not an expert programmer and couldn't tell you the difference between COM and .NET.  I'm sure one of you gurus will know right away what my issue is.  I really appreciate any help someone can provide.  Thanks guys!
Jeff_M
  • C3D user & customizer
Re: Survey Figures - cannot find Basecurve method?
« Reply #1 on: May 30, 2014, 11:04:21 AM »
BaseCurve is a property, you are using it like a method. This should work (although I don't speak VB too well):
I'm pretty sure you can do something like this, too (it works in C#, not sure of the context in VB):
Dim survFig As Curve = TryCast(TR.GetObject(Res1.ObjectId, OpenMode.ForWrite), Curve)
Oh, as I was changing that last line I realized you are casting the Figure as an Aecc object, which is COM, so will not work any way as BaseCurve is a property of the managed API SurveyFigure object.
surveyor_randy
« Reply #2 on: May 30, 2014, 11:58:27 AM »
Great!  Thank you very much Jeff!
It seems I was missing references to AecBaseMgd.dll and AeccDBMgd.dll
You got me on the right track!  :-)
