aahhhhhhhhhhh, its not fair!
using System;
using System.Linq;
using System.IO;
using System.Threading;
using AcAp = Autodesk.AutoCAD.ApplicationServices;
using AcEd = Autodesk.AutoCAD.EditorInput;
using AcGe = Autodesk.AutoCAD.Geometry;
using AcRx = Autodesk.AutoCAD.Runtime;
using AcDb = Autodesk.AutoCAD.DatabaseServices;
using AcWd = Autodesk.AutoCAD.Windows;
[assembly: CommandClass(typeof(search.Commands))]
namespace search
public static class Commands
[CommandMethod("doit")]
public static void doit()
Editor ed = AcAp.Application.DocumentManager.MdiActiveDocument.Editor;
List<string> strlist = new List<string>();
PromptStringOptions pso1 = new PromptStringOptions("Enter path");
pso1.AllowSpaces = true;
PromptResult prs1 = ed.GetString(pso1);
if (prs1.Status != PromptStatus.OK)
return;
PromptStringOptions pso2 = new PromptStringOptions("Enter String to search");
pso2.AllowSpaces = true;
PromptResult prs2 = ed.GetString(pso2);
if (prs2.Status != PromptStatus.OK)
return;
string[] strarray = GetDwgFilesFromDir(prs1.StringResult);
try
Parallel.For(0, strarray.Length, delegate(int i) //<----------------------------
using (Database db = new Database(false, true))
db.ReadDwgFile(strarray[i], FileShare.Read, true, "");
AcDb.TransactionManager Tm = db.TransactionManager;
using (Transaction tr = Tm.StartTransaction())
BlockTable tb = (BlockTable)tr.GetObject
(db.BlockTableId, OpenMode.ForRead, false);
BlockTableRecord btr = (BlockTableRecord)tr.GetObject
(tb[BlockTableRecord.ModelSpace], OpenMode.ForRead, false);
foreach (ObjectId id in btr)
DBObject dboject = (tr.GetObject(id, OpenMode.ForRead));
if (dboject is MText)
MText mt = (MText)dboject;
if (mt.Text.ToUpper().Contains(prs2.StringResult.ToUpper()))
strlist.Add(strarray[i] + " contains string: " + prs2.StringResult);
db.CloseInput(true);
foreach (string str in strlist)
ed.WriteMessage("\n" + str);
catch (System.Exception ex)
ed.WriteMessage(ex.Message);
//this function needs .NET 3.5 to run/compile
public static string[] GetDwgFilesFromDir(string path)
var MyList = from f in Directory.GetFiles((path))
where Path.GetFileName(f).ToUpper().Contains(".DWG")
select f;
return MyList.ToArray();
