Author Topic: SubClass 100 values  (Read 1205 times)
David Bethel
SubClass 100 values
« on: May 22, 2014, 07:26:01 AM »
Other than when required to included the SubClass 100 values in an (entmake), does anyone use the blasted things?
They've been around a while and I've seldom see them used ?
-David
R12 Dos - A2K
gile
  • Marseille, France
Re: SubClass 100 values
« Reply #1 on: May 22, 2014, 08:08:21 AM »
These groups describe the inheritance relationship between classes. They can be used while inspecting a DXF list.
For example, the DXF list of an attribute reference:
Code - Text: [Select]
  1. ((-1 . <Nom d 'entité: 7ffffb06a50>)
  2.   (0 . "ATTRIB")
  3.   (330 . <Nom d 'entité: 7ffffb06a40>)
  4.   (5 . "1E45")
  5.   (100 . "AcDbEntity")
  6.   (67 . 0)
  7.   (410 . "Model")
  8.   (8 . "0")
  9.   (62 . 0)
  10.   (6 . "ByBlock")
  11.   (370 . -2)
  12.   (100 . "AcDbText")
  13.   (10 129.005 313.129 0.0)
  14.   (40 . 2.5)
  15.   (1 . "test")
  16.   (50 . 0.0)
  17.   (41 . 1.0)
  18.   (51 . 0.0)
  19.   (7 . "Arial_std")
  20.   (71 . 0)
  21.   (72 . 4)
  22.   (11 131.819 314.331 0.0)
  23.   (210 0.0 0.0 1.0)
  24.   (100 . "AcDbAttribute")
  25.   (280 . 0)
  26.   (2 . "ATT1")
  27.   (70 . 8)
  28.   (73 . 0)
  29.   (74 . 0)
  30.   (280 . 1)
  31. )
The AcDbAttribute class inherits from the  AcDbText class which inherits from the AcDbEntity class (which inherits form AcDbObject).
Before the (100 . "AcDbEntity") are the common properties for all AcDbOject instances.
Between (100 . "AcDbEntity") and (100 . "AcDbText") are the AcDbEntiy specific properties which are common to all entities (all AcDbObject aren't entities i.e. layer, BlockTable, dictionaries...)
Between (100 . "AcDbText") and (100 . "AcDbAttribute") are the AcDbText specific properties (attribute definitions and attribute references, for example, inherit from AcDbText)
After (100 . "AcDbAttribute") are the attribute specific properties.
David Bethel
« Reply #2 on: May 22, 2014, 01:24:06 PM »
I've never seen the structure broken down in that way.  Very interesting.    :kewl:
But... Do you use it ?
R12 Dos - A2K
« Reply #3 on: May 22, 2014, 03:09:23 PM »
Great explanation gile, thanks  :-)
