Code Red > VB(A)
VBA and Databases
M-dub:
Thanks Hendie,
I did all that stuff, but I'm still getting the errors. It works fine if I run it from the VB environment, but ALWAYS get the error if I just type tblock2000 at the command prompt...
Any other ideas?
hendie:
open the lisp and change
--- Code: ---(setq f (findfile "tblock.dvb"))
--- End code ---
to
--- Code: ---
(setq f (findfile "tblock2000.dvb"))
--- End code ---
***EDITED***
and I still got errors... so try changing
--- Code: ---(vl-vbaload "tblock2000.dvb")
--- End code ---
to
--- Code: ---
(vl-vbaload f)
--- End code ---
and it should run
M-dub:
Hendie, you're bloody brilliant!
Thanks a million!
I can now hack this to bits and see how I can use it for our own application. Hopefully after our little course is over, I'll become a major player in this particular forum. I have seen many many uses for VB in my position where I am right now so I'll likely be in here getting (and hopefully GIVING) help far more frequently.
Thanks again, Hendie...Greatly Appreciated!
Mike
Navigation
[0] Message Index
[*] Previous page
Go to full version
