Author Topic: DXF File and Viewports.  (Read 3198 times)
SDETERS
« on: December 07, 2007, 10:09:14 AM »
Please tell me what I need to do to be able to see the drawing in Model Space.  The part looks good in the layout view but when I switch to model space I get nothing.  This file was translated from a different 2D 3D modeling package.  Thanks  Drawing is attached.  We are trying to open it in 2007   When I open it in 2004 it comes in ok.  But not 2007.
« Last Edit: December 07, 2007, 10:14:03 AM by SDETERS »
Rob...
Re: DXF File and Viewports.
« Reply #1 on: December 07, 2007, 10:13:29 AM »
I'm getting a fatal error in MEP2008 when I try to open it. Tried to recover but no go.
CAD Tech
Josh Nieman
« Reply #2 on: December 07, 2007, 10:13:42 AM »
heh.. sorry, crashes my AUtocad.
SDETERS
« Reply #3 on: December 07, 2007, 10:15:40 AM »
Crude sorry about that.    Thanks for tying
SDETERS
« Reply #4 on: December 07, 2007, 10:19:01 AM »
Try this file out Pleaseeeeeeeee
I opened it up in 2007 and save it as a 2007 dwg
If this crashes your machine I am sorry again.  Thanks
Josh Nieman
« Reply #5 on: December 07, 2007, 10:20:10 AM »
newp.
Sorry man... still fatal. :(
Josh Nieman
« Reply #6 on: December 07, 2007, 10:20:51 AM »
nm, recover worked on the second file.
Josh Nieman
« Reply #7 on: December 07, 2007, 10:21:34 AM »
Call me goofy, but I don't see the difference between the display of the model through a viewport in layout, and the display of the geometry in model space?
Josh Nieman
« Reply #8 on: December 07, 2007, 10:24:11 AM »
Here's what I see, screenshot'd.
SDETERS
« Reply #9 on: December 07, 2007, 10:25:20 AM »
Did you have to do something with viewports or what not to get the model to display in Model Space?
I did a recover for the heck of it and now I get the part to look like I want in model space.  This is getting weird I hate the translated drawings.
That is it.  I guess the answer is to run recover on all of the translated files I get from this system.  Thanks for the help
Josh Nieman
« Reply #10 on: December 07, 2007, 10:29:20 AM »
All I did was use 'recover' to open the file once I saved it.  Cool, glad it works for ya, now.
« Reply #11 on: December 07, 2007, 10:31:25 AM »
I got this wit ACAD2000:
Unknown value "AC1018" encountered in drawing version.
Invalid or incomplete DXF input -- drawing discarded.
« Reply #12 on: December 07, 2007, 10:33:53 AM »
Late to the party and don't know if this will help but I created a new document from the original dxf file, junked paperspace in it's entirety (easy enough to recreate viewports et al) and purged all the extraneous layers etc.
Attached (2007 format).
SDETERS
« Reply #13 on: December 07, 2007, 11:17:47 AM »
How did you do all of this?  Did you modify the DXF file?
« Reply #14 on: December 07, 2007, 11:32:13 AM »
I started with a pristine dwg (new with no template), inserted (exploded) the the original dxf file, and then nuked the superfluous stuff like paperspace, layers etc.
Should be noted that this technique will change entity handles. I saw nothing in the dxf file that suggested this would be a problem, but on drawings that are handle dependent (e.g. AutoPlant, Architectural desktop yada) it can have disastrous impacts upon linked intel.
To clarify though, no, I did not modify the original dxf file.
