Author Topic: Things that make you say "ARRRGGGHH!!!"  (Read 7369 times)
M-dub
« Reply #15 on: September 24, 2004, 11:23:37 AM »
Dan, Have a look HERE
ELOQUINTET
« Reply #16 on: September 24, 2004, 11:27:34 AM »
pretty cool unfortunately i'm not in a position to do that sort of thing (unfortunately)  :?
« Reply #17 on: September 24, 2004, 11:37:27 AM »
Quote from: t-bear
Speakin of which, I need to hire a new draftie around the end of Oct to mid Nov.  Any ideas on how to test these wanna-be CADers?  3D and MS/PS are a must............ I have some ideas but am open to suggestions.
I find questions that allow the user to reveal their own stupidity / expertise work rather well.
"We're starting a new project, what scales would you recommend for modelspace?" (Trick question).
"Where's the best place to place floating viewports?" (Trick question).
"How would you instruct a collegue to create a tapered extrusion?"
"I'm new to 3D, explain in simple terms what it means if an object's normal projects due south."
Etc.
If the candidate truly knows what he / she is doing these questions will be fun and / or easy, otherwise they'll be going "Umm, well, errr".
« Reply #18 on: September 24, 2004, 11:46:47 AM »
Quote from: MP
Now there's a good idea for a thead. CAD test questions :D
VerticalMojo
« Reply #19 on: September 24, 2004, 12:00:50 PM »
good Idea Mark.... Common questions heard or you have come across
« Reply #20 on: September 24, 2004, 12:30:03 PM »
Quote from: t-bear
ME!!! ME!!! ... oh wait ... nevermind ... I'd never get Dr.Demento to go to Missery
MP ... Ok I'm stupid ... just what does it mean when an object's normal projects south?
I can model with the best of them and in 5 years I have never heard this expression.
On the other questions how is this ....
1) I always recommend a 1:1 but If you want the modelspace drawing a different scale then I can make that happen as well... I just don't recommend it.
2) Uh .. in PS... unless your trick is in reference to the "floating" part ... but by nature aren't all viewports in PS "floating"? Unless you are referring to the "non-floating" fixed viewports you get when Tilemode is set to 1 and the vports command is issued.... but the whole issue was supposed to be a trick now wasn't it...
3) Depends.... typically ...extrude ... set height ... set taper angle ... unless the angle is not known but the height and "depth" of taper is known ... then I would chamfer the object ... of course presuming the taper as specified can exist on that particular object, or I might simply select the plane on which it is to be tapered and subtract the uneeded portion ... it all depends of course on the shape of the object....
ELOQUINTET
« Reply #21 on: September 24, 2004, 12:36:22 PM »
you're hired  8)
« Reply #22 on: September 24, 2004, 01:17:12 PM »
Quote from: Keith
It means the object was created when the UCS was rotated +90° about the Y-Axis or it was rotated same after creation in the WCS.
As for your other responses they reveal a good understanding of the material. You made the short list.
Now then, do you play guitar? No? Thank you for your participation, we sincerely wish you luck in your future endeavors.
:D
ELOQUINTET
« Reply #23 on: September 24, 2004, 01:29:04 PM »
do you have a hot girlfriend i can gawk at no that's too bad we'll call you  :wink:
megamike
« Reply #24 on: September 24, 2004, 01:31:40 PM »
We have an arkeetek here who refuses to use the standard layers cause his colors "just look better on the screen"
Same guy: does not know how to use paper space, so he inserts a title block in model space (I can live with that) then decides his drawing needs to be 1/4" scale instead of 1/8" scale and proceeds to scale the MODEL! (of course he had to first explode all of the dimensions!!!)
« Reply #25 on: September 24, 2004, 01:31:43 PM »
Quote from: MP
Quote from: Keith
:D
Uh... I used to play guitar ... like 20 years ago ... I went through some real tough economic times and pawned my Gibson, sold my others outright ... never retrieved it from pawn ... and never picked another tune .. well, I uh.. tried to a couple of years ago, but I was sooo terribly out of practice and my poor fingers hurt me so bad, I decided against buying another guitar... I don't really have the time for it anyway...
« Reply #26 on: September 24, 2004, 01:37:04 PM »
Quote from: megamike
Adhering to standards is a condition of employment at our camp ... he would last about 3 days.
« Reply #27 on: September 24, 2004, 01:38:32 PM »
Quote from: Keith
Shame you gave up; nice try on the too buzy angle. :D
« Reply #28 on: September 24, 2004, 01:45:04 PM »
Can you blame me for trying?
megamike
« Reply #29 on: September 24, 2004, 01:47:28 PM »
[/quote]
Adhering to standards is a condition of employment at our camp ... he would last about 3 days.[/quote]
Mention standards around here, and eyes glaze over! :shock:
