Author Topic: Hmmm, code not working in Ac2014?  (Read 4788 times)
Bob Q
« on: January 24, 2014, 05:51:53 PM »
"ActiveX Server returned an error: Error loading type library/DLL"
I am not sure exactly what it triggering this, but one of my routines, I think it is a "get_center_of_objects"...
Anyone run into anything like this?
vl-load has already run.
Thanks!
irneb
Re: Hmmm, code not working in Ac2014?
« Reply #1 on: January 25, 2014, 12:13:37 AM »
Do you know which TLB/DLL file it was trying to load? Is it perhaps not in a folder which Windows can find? Do you have an older acad installed, in which these routines still work?
GP
  • Vercelli, Italy
« Reply #2 on: January 25, 2014, 06:02:45 AM »
Bob Q
« Reply #3 on: January 25, 2014, 02:10:14 PM »
Yes, the older version, which I still have installed, works.
Bob Q
« Reply #4 on: January 25, 2014, 02:41:21 PM »
Command: (vla-getBoundingBox vla 'MinPoint 'MaxPoint)
I narrowed it down to the above command. Below is the error:
errorActiveX Server returned an error: Error loading type library/DLL
« Reply #5 on: January 25, 2014, 06:11:27 PM »
Do you get the same error with:
(vlax-invoke-method vla 'getboundingbox 'a 'b)
And:
(vlax-invoke vla 'getboundingbox 'a 'b)
Bob Q
« Reply #6 on: January 25, 2014, 06:16:07 PM »
I will check it out....
On a side note, you ride / race?
« Reply #7 on: January 25, 2014, 06:19:19 PM »
I ride (CBR600F) but don't race - sorry to disappoint, but that isn't me in my avatar  :angel:
Bob Q
« Reply #8 on: January 25, 2014, 06:45:17 PM »
LOL, cool, I have 3 cbr1000rr's and a 600rr, awesome fun!
Bob Q
« Reply #9 on: January 25, 2014, 07:11:56 PM »
And:
Pretty much the same error, although the last option is reported slightly differently. Ugh!
Command: (setq vla (vlax-ename->vla-object ent))
#<VLA-OBJECT 00000000475cb448>
Command: (vlax-invoke-method vla 'getboundingbox 'MinPoint 'MaxPoint)
Command: (vlax-invoke vla 'getboundingbox 'MinPoint 'MaxPoint)
errorError loading type library/DLL
« Reply #10 on: January 25, 2014, 07:20:14 PM »
It sounds like the ActiveX type library (vl16.tlb / vlcom.dll?) is missing or corrupt - have you tried to repair the installation?
« Reply #11 on: January 25, 2014, 07:20:31 PM »
Nice!  :-)
Bob Q
« Reply #12 on: January 25, 2014, 07:26:39 PM »
I think I did the other day, mabye not though. I will try again.
Is there any way to verify where these are, file sizes or something?
Or is all that can be done is re-install?
Thanks!
owenwengerd
« Reply #13 on: January 25, 2014, 07:29:13 PM »
I suspect the error comes from failing to create the ActiveX wrapper for the object. It would be helpful to know what type of object it is.
Bob Q
« Reply #14 on: January 25, 2014, 07:31:28 PM »
In this case I am selecting a circle for the object in question.
