Author Topic: lisp to read ms word documents  (Read 5295 times)
andrew_nao
« on: March 01, 2013, 10:25:35 AM »
is it possible?
any tutorials?
any examples I can learn from?
thanks
irneb
Re: lisp to read ms word documents
« Reply #1 on: March 02, 2013, 05:25:55 AM »
It would be similar to reading Excel files. I.e. you link to Word through ActiveX and open or use an already opened document. From there you'll need to figure out how the Word ActiveX library works - do some googling on Word VBA.
andrew_nao
« Reply #2 on: March 04, 2013, 09:59:32 AM »
ive been googling it for a couple days before i asked here
i dont know what vba code to look for
and anything lisp wise for this is limited.
i was hoping maybe someone here had a link or a tutorial or example code they would be willing to share so i could learn.
ill keep searching
« Reply #3 on: March 04, 2013, 10:08:32 AM »
See what this does:
The .12 portion of the string may be different depending on the version of Office you have installed.
andrew_nao
« Reply #4 on: March 04, 2013, 10:28:29 AM »
See what this does:
lol here is what is returned.. ill have to go thru this a little at a time but maybe someone else could use the info
« Reply #5 on: March 04, 2013, 11:03:14 AM »
This might be a little more help. See if you can pick this apart  :-)
(defun c:test (/ doc docs result wa words)
  (and (setq wa (vlax-get-or-create-object "Word.Application"))
       (setq docs (vlax-get wa 'documents))
       (setq doc (vlax-invoke docs 'open "C:\\test.docx"))
       (setq words (vlax-get doc 'paragraphs))
       (vlax-for word words (setq result (cons (vlax-get (vlax-get word 'range) 'text) result)))
       (foreach line (reverse result) (alert line))
andrew_nao
« Reply #6 on: March 04, 2013, 11:11:17 AM »
thanks Ronjob, this is good learning code for me
one thing, i cant open the file now.
i need to close it but
(vla-close Docs) doesnt work whats missing?
andrew_nao
« Reply #7 on: March 04, 2013, 11:13:08 AM »
oopps never mind its closed.. dunno what that was about tho..
« Reply #8 on: March 04, 2013, 11:16:15 AM »
You can use (vlax-invoke doc 'close) to close  :-)
andrew_nao
« Reply #9 on: March 04, 2013, 11:25:13 AM »
this is excellent
thanks again, sir
« Reply #10 on: March 04, 2013, 11:36:23 AM »
Glad to help  8-)
« Reply #11 on: March 04, 2013, 11:45:58 AM »
Be careful to release the Word Application object when operations have finished, and to also include the required error trapping to ensure that this object is safely released should an error occur whilst interfacing with the word document.
Also, you will need to use the Quit method of the Application object to close the Word Application before releasing the object, otherwise the winword.exe process will remain active with no possible way to access the application without terminating the process manually using the Task Manager.
In short, it is good programming practice to clean up after yourself  :-)
andrew_nao
« Reply #12 on: March 04, 2013, 11:59:56 AM »
thats funny i was just going to ask this.
i notice in an excel function it says this for error handling
would this be the same but with my variables?
  (defun *error* (msg)
    (and msg
(/= msg "Function Canceled")
    (and wBook (vlax-invoke-method wBook 'Close :vlax-False))
    (and xlApp (vlax-invoke-method xlApp 'Quit))
    (and reg (vlax-release-object reg))
    (mapcar (function (lambda (obj) (and obj (vlax-release-object obj))))
    (list rng wBook xlApp)
    (gc)
also the doc file opens and closes after running the code
i tried
(vla-put-visible doc :vlax-false)
but that doesnt work, whats the equivalent of this?
or how do stop the doc from popping up and closing?
where should i be looking for the vlax functions?
« Last Edit: March 04, 2013, 12:03:57 PM by andrew_nao »
« Reply #13 on: March 04, 2013, 12:28:23 PM »
To hide Word try using (vlax-put wa 'visible 0).
andrew_nao
« Reply #14 on: March 04, 2013, 01:56:18 PM »
how can i get the header and footer info?
